      08-16-2016, 11:23 AM   #1
500AF
Drives: 2013 135
Tire Square Question
I have two sets of stock wheels for my 135i. Does anyone know if the I can square up the front using the extra rears I have with the 245 tires on them?
Thanks,
      08-16-2016, 02:31 PM   #2
E82MSport
E82MSport's Avatar
Drives: 08' Crimson 135i
ET52 stock rears with 12mm spacers will fit the 245/35's. If you're lowered you might have fender clearance issues and need more camber or a fender roll.
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
      08-16-2016, 03:39 PM   #3
1and1
Loves me some MHD!
1and1's Avatar
Drives: faster than he should...
'09 135i  [10.00]
Which stock wheels do you have? I'm curious about the same thing...
1and1
135i - E82.N54 2009 BSM - MHD / xHP / DCI, PR CP & 7.5" Race IC / N55 mid & Borla
. . WL RSFI, Koni, Eibach & Dinan CP's, M3 CA's / EBC Red's & Firehawk 500's
X1 - E84.N20 2013 MGM - JB4 - The Wife's, now with new turbo & ewg
      08-16-2016, 04:19 PM   #4
lowbudgethero
lowbudgethero's Avatar
125
Drives: '98 Z3M (gone), '09 135i
2009 BMW 135i  [8.50]
I'd recommend 10mm spacers over 12, I found the 12's with 255s would rub really bad on the bumper tab. YMMV though depending on your tire brand and size.
      08-17-2016, 12:48 AM   #5
spxxx
Boost
spxxx's Avatar
1354
Drives: 135i M-Sport
I run square M261 rims with ~265mm tires on all four sides with 7mm spacers up front - lowered with -2* camber up front.
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
      08-17-2016, 06:46 AM   #6
500AF
Drives: 2013 135
Mine are the stock type 261 wheels with the M option. I am really curious how much more grip you guys get running the 245's up front.
Needless to say last year I slide off the road when the front washed out on a 90 degree turn. Not sure why bmw put a 215 up front.
Is it a noticeable difference in look out front?
spxx would love to see a picture of what yours looks like if you don't mind.
      08-17-2016, 05:50 PM   #7
lowbudgethero
125
the extra front grip completely changes the car
      08-17-2016, 11:18 PM   #8
wjk_glynn
wjk_glynn's Avatar
167
Drives: 997.2 C2S Coupé
Here are details on my square 264 setup: http://www.1addicts.com/forums/showthread.php?t=1170959
Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers
      08-20-2016, 11:50 PM   #9
joeo
Drives: 2009 Crimson Red 135i
2009 BMM 135i  [9.50]
I'm running a square setup with 255/35 R18s on the 261 style wheels (2 sets of rears). I'm running 12mm spacers from turner motorsports up front, rolled front fenders, and shaved bumper tabs.
TC Kline DA kit with vorshlag camber plates. On track I rubbed a hole in the fuel filler plastic tube in the rear. Anyone else have that issue? As to solutions, I could put maybe a 5mm spacer on the rear, or perhaps some clever way of re-routing the fuel filler? Any ideas?
Thanks!
-Joe
      08-21-2016, 10:20 AM   #10
dcaron9999
dcaron9999's Avatar
Drives: 2011 135i M package
Similar to Joeo -
Previous track setup, and now rain setup: I'm running a square setup with Dunlop Direzza ZII SS 255/35 R18s on "261 style" wheels (2 sets of rears), with 10mm spacers up front, rolled front fenders, and shaved bumper tabs.
New track setup: I'm running a square setup with Nitto NT-01 255/40 R17s on "68 style" wheels (2 sets of rears), with 10mm spacers up front.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
      08-21-2016, 11:42 AM   #11
joeo
I'm running Toyo R888s all around. dcaron9999 - did you have any issue with the fuel filler being rubbed in the rear? Are the 68 style rims from an E46 M3? Same offset as the 135i wheels?
Thanks.
-Joe
      08-22-2016, 09:32 AM   #12
500AF
Drives: 2013 135
Does anyone know if I can fit 255's in the rear on the stock wheels without using spacers.
I got the spacers for the front 10mm and will be putting 245's in the front.
      08-22-2016, 09:45 AM   #13
joeo
255/35 R18s fit fine on the rear with the stock suspension.
      08-26-2016, 04:38 PM   #14
optigrab
More Boost?
optigrab's Avatar
Drives: 08 135i MSport 6AT
wow how much tire to strut clearance do you have?
I have less than a finger with 264 wheels 245 tires 12 mm spacer at stock height/ alignment
      08-26-2016, 05:12 PM   #15
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
What tires and Struts? I'm using Bilstein B8 and 245MPSS tires with 7MM spacers and the tire rubbed the paint off the strut.
      08-26-2016, 07:40 PM   #16
spxxx
Boost
spxxx's Avatar
1354
Bilstein pss9 coils must be thin. I just installed Apex ET45/58 Arc-8 with 3mm spacer and 255/35/18 tires all around. No rub anywhere except full lock
      08-31-2016, 11:38 AM   #17
500AF
Drives: 2013 135
I only got the 10 mm spacers for the front. I am assuming I don't need them for the rear and they wouldn't work anyway in the rear with stock suspension and 255 tires on the stock rear wheels.
Does anyone know if that is correct?
      08-31-2016, 03:06 PM   #18
Ginger_Extract
California-bound
Ginger_Extract's Avatar
Drives: BMW 135i
Thanks!
-Joe
Common issue. Had the same problem with 18x9.5 Apexes and a 255/35. Currently running 5mm spacer, for effective offset of 57 and it's fine. Will move to a lower offset wheel when I want to go wider than 255.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18
https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3
      08-31-2016, 08:10 PM   #19
joeo
Thanks Ginger_Extract - I went with a 3mm spacer, and I'm going to slightly modify the filler pipe. That's my plan anyway.
-Joe
      10-07-2016, 07:52 PM   #20
500AF
Drives: 2013 135
Karl.
Talk about threading the needle... I put the 245's up front and it is really close to the shock, about 3mm. I will post some pictures. Mine are the stock type 261 I believe. I got the 10mm offset like your setup.
      10-07-2016, 08:23 PM   #21
brocklanders
brocklanders's Avatar
106
Drives: the uno, mineral white
06 325  [0.00]
Originally Posted by dcaron9999 View Post
Similar to Joeo -
I'm on my second set of zII's, how would you say the Nitto's compare?
      10-07-2016, 08:59 PM   #22
Ric in RVA
Bergspyder
Ric in RVA's Avatar
Drives: '11 BMW 128i Sport 6mt
Could you run a set of rally or winter tires on 4 fronts???
Ric in RVA
2011 128i 6 MT Sport, 2009 Cayman 987.2, 2011 528i N52, 2018 F150 Platinum
1addicts
