      08-11-2016, 11:47 PM   #1
eboosted
Peru
31
Drives: x6 5.0i xdrive 2009
TSW Bathurst on 135i E82
These wheels look amazing on the 135i they even look as big as 19s because of the ultraconcave design, the offset is pretty agressive but we are doing fender rolling next week, so it should fit good afterwards. BTW the wheels are extremely light and rotary forged.
Front 18x8.5 ET35
Rear 18x9.5 ET39
Hankook Ventus R-S3 225/40R18
Hankook Ventus R-S3 255/35R18
      08-12-2016, 01:25 AM   #2
GR1P
GR1P's Avatar
33
Drives: 135is
They match the M badge perfectly
twin fed1175.50
Loho7.50
      08-12-2016, 06:06 PM   #3
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
Ouch.
2010 135i 6MT Jet Black
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      08-15-2016, 12:32 AM   #4
kb135
kb135's Avatar
Australia
21
Drives: 135i Space Grey
Let us know how the fender rolling goes and post some pics up afterwards of the fenders please. curious to see if you get away with just a roll or if a pull is needed.
      09-08-2016, 07:32 AM   #5
AGM2
AGM2's Avatar
Drives: M2 LBB 17
[QUOTE=eboosted;20399774]These wheels look amazing on the 135i they even look as big as 19s because of the ultraconcave design, the offset is pretty agressive but we are doing fender rolling next week, so it should fit good afterwards. BTW the wheels are extremely light and rotary forged.
Front 18x8.5 ET35
Rear 18x9.5 ET39
Weight is 18.3lbs/each
      09-10-2016, 06:36 AM   #6
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Awesome weight.
      09-20-2016, 08:23 AM   #7
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
So how did the fender roll go?
      09-20-2016, 12:17 PM   #8
eboosted
Peru
31
It came out pretty good, no rubbing at all even at max compression.
Here are somepics of the procedure, unfortunately I don't have pictures of the final outcome
John_01232.00
      09-20-2016, 01:14 PM   #9
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Nice. What is the gray stuff?
      09-20-2016, 02:52 PM   #10
eboosted
Peru
31
Wink
It's primer
      09-20-2016, 04:00 PM   #11
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Can you elaborate? Why was primer required to roll your fenders? Did they have to remove the sealant above the fender lip before doing the roll?
      09-20-2016, 04:22 PM   #12
eboosted
Peru
31
The procedure was to modify the metal sheet of the fender with a frame pulling tool and solder torch, then flatten the sheet and prime it before painting it. The cost was roughly 300 bucks, including pull and painting
      09-20-2016, 05:13 PM   #13
houtan
houtan's Avatar
707
Drives: 2011 135i
2011 135i  [9.80]
Woah. That is much more than just a fender roll. Glad it turned out good. Thanks for the info.
      09-20-2016, 05:15 PM   #14
eboosted
Peru
31
The good thing is we have no rubbing at all with a ET39 offset wheel
      09-23-2016, 01:44 AM   #15
thewubwub
thewubwub's Avatar
76
Drives: like a slowpoke
Front 18x8.5 ET35
Rear 18x9.5 ET39
Looks good! Stock suspension?
      09-23-2016, 04:02 AM   #16
perfor
Sweden
Drives: BMW e82 135i -08 Cobb stage 2+
Nice! 👌
      09-24-2016, 07:05 PM   #17
John_01
John_01's Avatar
Australia
232
Drives: E90 325i, E82 135i
Cool fender mod
      09-24-2016, 10:30 PM   #18
Eyeman
Eyeman's Avatar
121
Drives: 2008 135 blk, blk, step
Very cool. The other option was the rear brake hub mod but your way comes out looking much cooler if done right.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
      10-05-2016, 05:07 PM   #19
brocklanders
brocklanders's Avatar
106
Drives: the uno, mineral white
06 325  [0.00]
The wheels look great, I like them, but do you think you can get wider tires on there now after your fender modifications? I don't mean to be a downer but I don't see the reason to put wider wheels on the car if you can't put wider tires. I commend your choice of tires and I understand the situation, that BMW gave us compact car sized wheels on a 300hp vehicle so our choices for wheels are limited. I'm actually jealous, I would love to be able to at least get a 235 up front.
      10-05-2016, 07:00 PM   #20
eboosted
Peru
31
According to Tirerack the recomended wheel width for a 255/35R18 is between 8.5-10" so 9.5" is the sweet spot, the "tread width meassuring" which is the surface in contact with the road in this case is 9.3"
With a 265/35R18 the recomended wheel width is between 9-10.5" being the sweet spot a 10" width wheel, the tread width is 9.7" only 0.4" more in contact with the road and only if you use a 10" wheel, with the same wheel width of 9.5" you should be getting 0.2" more surface contact with the road. Not worth it.
      10-05-2016, 07:42 PM   #21
John_01
John_01's Avatar
Australia
232
Those RS-3 hankooks look like a good fit on the 9.5" rims. If you have a tire with a firm sidewall, then it may make sense to use a 265.
I think both sizes are good options depending on what you want to use it for.
      10-06-2016, 04:59 PM   #22
dbronnik
dbronnik's Avatar
223
Drives: N54 E88
1addicts
