08-07-2016, 03:34 AM | #1 |
Rep 487
Tire size recommendations 8.5/9.5 19' et45
Looking for tire recommendations in regards to size and brand.
First hand experience with similar wheel specs please. I would like to do little to no fender work.slight fender roll would be okay. Will be going for absolute minimal tire/fender gap, no "tucking". Im currently on stock m sport suspension.i will be doing coil-overs in the next two months. In order of importance. 1.grip/handling dry weather 2.mileage 3.road nose/comfort Wheel specs as followed: 19' 45et 8.5/9.5 |
08-07-2016, 11:10 AM | #2 |
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
The best tire IMO for your importance categories is the Michelin PSS. However, I have wheels with very similar dimensions so I know from experience that if you want to get a good tucked look, you will not get it with the PSS (my mods are listed below). Other factors will be how much camber you are running, how low you go, etc. I even modded my rear hubs to tuck my wheels in further so I could run wider rear tires.
My first set of tires with these wheels were ToyoT1Rs, 225/35fr, 255/30r, they easily fit, lasted a very long time, quiet, decent traction. I now have Nitto 555s 225/35 up front, but in the rear they are only available 265/30, I believe that would fit and tuck easier than the 255/30 PSSs that I'm currently using. Some with our size wheels use 245/35 rears to try to get things to fit. I assume you searched and saw a lot of threads discussing wheels this size. Basically no one has found a perfect combo, it really depends on how much rubbing or how much camber or stretched tire you will tolerate.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
08-08-2016, 05:37 PM | #3 |
1Addict
3234
Rep 7,894
You're not going to get a 265 tire on there with a drop and a 19x9.5 et 45 rear wheel and no rubbing without rolling the fenders at least a little.
I'd do a 255/30 tire first. If you have enough room, try a 265 next year.
08-10-2016, 03:10 AM | #4 |
Member
15
Rep 46
what coil-overs do you have in mind? michelins have always been #1 on my list (will run wider than other brands), great at absorbing road noise and love the grip/response. I'd stick with the 225/35 - 255/30. I've seen a few threads with this particular wheel/tire spec and it looks great. may consider rolling the rear fender to be safe and avoid any rubbing. don't forget, offset is the game changer when you decide to go with a wider wheel/tire setup.
