07-12-2016, 02:58 PM | #1 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
Do I have my tires on right?
So I got to thinking and I just wanted to make sure the orientation of my tires are correct. I got the staggered sport style 262 wheels (Sumitomo Touring Plus LSW 205/50R17 + 225/45R17)
These only say "outside" and all of the wheels say it on the outside, so would this be correct? Or do they matter left/right as well?. Can I rotate these (from left/right, I know not front/back)? Pictured is front passenger wheel, excuse the super dirty rim Last edited by desertman123; 07-12-2016 at 03:16 PM.. |
07-12-2016, 03:04 PM | #2 | |
Rep 1,233
07-12-2016, 03:11 PM | #3 | |
2214
Rep 2,219
Drives: '08 128i
I was kinda hoping the tires were on wrong - my wet performance is abysmal, guess it's just what you get with these. Oh well, that's an excuse to shred these and get some higher quality rubber on it!! |
07-12-2016, 03:38 PM | #4 | |
European Editor
10589
Rep 22,992
What kind of tires are those? Are they new? bc they kind of look low on tire thread. Check the four digit build date(week/year, ie: 0215, means the tires were made in the second week of 2015). I bet these tires are older than five years. ??? Also... check that there is no directional arrow on the tire sidewall. good luck, Dackel
07-12-2016, 04:09 PM | #6 | |
2214
Rep 2,219
Drives: '08 128i
Here's the best pic I tried getting of the tread As silly as it sounds, I wanna make sure I didn't miss anything else. I saw some post about rotating tires and what to do/what not to do with directionals/asymmetric/whatever tires and figured I should just ask instead of guessing. |
07-12-2016, 04:16 PM | #7 | |
Rep 79
Asymmetric ones must be mounted with the outside side... outside! |
07-12-2016, 07:28 PM | #8 | |
European Editor
10589
Rep 22,992
Ok, so the tires are a little over two years old. That's ok. But over here in Germany, tires can not be older than one calendar year in order to be sold as "new tires". Most of the times when I have bought tires they have been only a few weeks old to maybe two months old. Still... the tire thread look low. Just make sure you have at least 4mm of tire thread. Over here in DE once the tires get down to 4mm's, its time to start looking for new tires. A new tire has 8 or 9mm's of thread. The reason why most Germans replace their tires at say 3mm's is because we have lots of bad weather and tires play such an important role in a car's safety. Maybe the tire compound is hard for long tire life, hence the poor wet weather performance. I really would not spend the money on rotating your tires. Just make sure your car has a good alignment done.
07-16-2016, 10:00 AM | #9 | |
2214
Rep 2,219
Drives: '08 128i
http://www.sumitomotire.com/cars/pro..._plus_lsw.aspx Seems these are budget all-seasons (damn previous owner!!). Combine that with the fact the depth is gettin low, it's no wonder I struggle for grip. Definitely gonna get some nice rubber on here once these are fried. Thanks for the help! |
07-22-2016, 01:57 PM | #10 |
Rep 281
Yeah as mentioned Asymetrical tires have an inside and an outside. Does not matter what direction they rotate in. Now there are a couple tires that are Asymetrical and Directional but that is pretty rare.
07-31-2016, 04:44 AM | #11 |
Rep 275
You should not rotate left to right because the tread will wear in the direction the wheel is rolling. To feel this, rub your hand along the tread in both directions on a used tire. It will be smooth in one direction and jagged in the other. With a staggered setup you don't rotate at all just buy new and keep it aligned.
