      07-08-2016, 02:24 AM   #1
Bomtillington12
Drives: E46 325i
Rim fitment quick question
I am looking to get a square set of 18x8 et 35 rims just wondering if they will fit with little to no rubbing i do plan on going low also i have searched but havnt found a definitive answer was thinking about running 225 35 r18 for tires
      07-08-2016, 02:43 AM   #2
John_01
John_01's Avatar
Australia
232
Drives: E90 325i, E82 135i
Your car is an E82 1 series? If so, you would be better off with ET40 or ET42. It will be a nice flush fitment for the front.
ET40 will be a good fit for the rear too, but you can put a small 3~5mm spacer on the rear if you really want to.
      07-08-2016, 09:12 AM   #3
Bomtillington12
Drives: E46 325i
Thanks for the reply its just that ecs tuning has a really good close out on some csl styles so your saying it may rub a bit but it'll work
      07-12-2016, 10:29 AM   #4
VMRWheels
VMRWheels's Avatar
2042
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
You should be fine. I'd recommend a 40 profile tire, instead of 35.
      07-13-2016, 10:40 AM   #5
E82MSport
E82MSport's Avatar
Drives: 08' Crimson 135i
Really, with an 18x8 ET35 225/40/18 square setup? No flame, just really curious because ET35 is really aggressive for the 1-series.
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
      07-13-2016, 11:33 AM   #6
VMRWheels
VMRWheels's Avatar
2042
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
It will be semi aggressive. You can also run a 215/40/18.
      07-18-2016, 01:42 PM   #7
deesea
Drives: 2009 135i
I've seen people run 18x8.5 ET35 on the front with a 245 section tire with no issues...So bizarre that everyone says ET35 is a no go, but one guy actually did it without any problems...dunno where the discrepancy lies.
      07-18-2016, 05:09 PM   #8
John_01
John_01's Avatar
Australia
232
That is possible if you have around -3.0 degree front camber, and maybe roll the front guards as well. I used ET38 front wheel and a 245 R-comp tire for track use. The camber makes a big difference.
      07-18-2016, 11:40 PM   #9
deesea
Drives: 2009 135i
for what its worth, he has a thread up on stanceworks and here...i believe it's a set of BBS CH-R's 18x8.5 ET35 fronts on 245 section tires. I believe he said he was around 2.X degrees of camber and no fender modifications.
I'm hopeful because I want to pick up a set of wheels that are 18x8.5 ET36. I figure a slightly skinnier tire and 2.X degrees of negative camber and I'll be good too.
1addicts
