07-04-2016, 01:17 PM | #1 |
Rep 330
Auto slalom: constant throttle or rally style lift turn throttle
A local m3 pro recommended using rally style lift turn throttle to go through the slalom in a z shape. I wonder if you guys agree or I should just stick with the traditional constant throttle s shape.
07-04-2016, 03:32 PM | #2 | |
Retired Curmudgeon
2985
Rep 4,047
You always backside the slalom cones going as fast as physics will allow you to and as close to the cones as possible. [u2b]www.youtube.com/watch?v=fzr2ffrwoQQ[/u2b] does a great job explaining it w/video and words.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
07-04-2016, 06:09 PM | #3 | |
Stop the hate, get a V8
3850
Rep 8,625
Try both and see what works best for you. Some FYI: at Bondurant last year, we learned to do the "Z" thing you described. Their logic was that it allows the weight to settle and keeps the car more controllable; the "S" thing means the car is always right on the edge.
Past: 2011.5 M3 sedan ZCP |
07-04-2016, 07:05 PM | #4 | |
Retired Curmudgeon
2985
Rep 4,047
07-05-2016, 12:53 AM | #5 |
Rep 330
I learned lift brake turn through the slalom in dirtfish rally school, it felt really good in their stock frs on gravel. You can actually use the "tank slapper" as the entry to the next cone on gravel. I haven't tried this in autox, but I remember sitting in one of our region's' national champion's corvette and it felt as if he too was pivoting the rear around each cone in the slalom.
07-05-2016, 11:07 AM | #6 |
Rep 5,483
I do rally style j turns in slaloms
The right answer does usually seem to be to backside each cone but use the last two to power through rather than try and dance the car right on the limit just from a confidence and repeatability perspective |
07-05-2016, 10:08 PM | #7 | |
3850
Rep 8,625
They didn't specify, but in general the things they teach are "applicable to most cars and situations". We were driving C7 Corvettes which are lighter than the M3 by a few hundred pounds.
07-05-2016, 11:17 PM | #8 |
Rep 330
interesting, do you brake before each cone or just lift abruptly?
07-08-2016, 10:50 PM | #10 |
Retired Curmudgeon
2985
Rep 4,047
Balancing weight is important. I like it.
07-08-2016, 10:54 PM | #11 |
Rep 5,483
If you ain't using your knee, elbow and shoulder pads in slaloms you're a chicken. Obviously with a car you have to open the front doors to get enough lean
07-12-2016, 05:34 PM | #12 |
Rep 969
I've used both techniques. The absolute key is to not be lazy by passing the easy entry slalom cones without attacking the backside of the first and then accelerate out of the last two. What happens in the middle is up to you but I tend to prefer a constant steady state of throttle.
Sold 2011.5 E92 M3 ZCP.
