07-01-2016, 11:17 PM | #1 |
Rep 19
Bolt on mods and dyno sheet
So finally I had a chance to get my car on a dyno. This was ran on a dyno dynamics. The car has been a blast and so far I've just done a few bolt ons. I look back and wish I would have done a jb4 but as the car sits currently I have installed dinantronics stage 2 tune, injen CAI, and just installed the afe high flow catted downpipes.
The rest of the car is stock other than the 295/30/19 pilot sport cup 2 tires. Have to say the tires have been a major improvement!! Couple of questions: Anybody know what kind of boost the dinantronics will run? How much more hp/tq do you all think the jb4 would run? Does the dynamics dynometer really show 12% less numbers? |
07-03-2016, 02:28 PM | #3 | |
Rep 342
07-04-2016, 12:17 AM | #4 |
Rep 19
Since I already have the dinantronics I was wondering if the vf hex flash would add benefit. I guess a better way to look at it would be if I did the vf hex flash would dinantronics(stage 2) do anything in addition to the flash.
07-04-2016, 03:20 AM | #5 | |
Rep 982
Doesnt dinan provide warranty? Isnt that what your paying the extra for with dinan If you plan to stack you shouldve just bought a jb4 I have a gad stage 2, dynoed at 548 hp and I plan to stack with a jb4 |
07-04-2016, 08:07 AM | #6 | |
660
Rep 1,059
07-04-2016, 10:50 AM | #7 | |
3441
Rep 79,211
Dynos are for measuring changes. Going to a dyno just for 1 number will never leave you understanding how much you gained. Everyone should do a stock pull on a stock vehicle, same dyno, before going to the dyno with modifications. |
07-04-2016, 03:06 PM | #8 |
Rep 891
07-04-2016, 10:31 PM | #9 | |
Rep 2,809
The DME is in full closed-loop control over fueling (AFR targets are perfect for stock turbos) and the stock ignition timing curve is already knock limited on pump gas. The only area of a flash tune that you would benefit from on pump gas would be possibly changing valve overlap, but it remains to be seen if there is any power locked away in the cam angles over the stock tuning. Flash tunes, such as VF Engineering's HEX tune for the S55, has other auxiliary features (such as an aggressive overrun burble) that the JB4 obviously doesn't have anything control over. If you don't have a ZCP/GTS and want those features and more, I highly recommend it. |
07-04-2016, 11:35 PM | #10 | |
Rep 19
I appreciate the insight, so thank you. The great thing about forums is to have an audience who can help teach others! One of the reasons why I went with the dinantronics over the jb4 was because it was indeed a supposed safer route for the engine. So in regards to the hex flash it would seem to make sense that this also doesn't increase the risk of just simply increasing boost or tricking sensors to allow the s55 to perform at higher levels? So to gain those gts like qualities I could obtain the hex flash and keep the dinantronics and still have some gain in features. I've tried to keep the car legal and reliable as of current. Now, who's to say that some pure turbos, injection port system and some other upgrades aren't in the stars at some point haha. |
07-05-2016, 03:19 AM | #11 |
Rep 3,411
The text in bold is key here. Thank you for clarifying that your preceding statements are merely opinion. So long as everyone else understands that it is not factual, we're all good.
