07-01-2016, 08:55 AM | #1 |
Rep 434
Switched to Non-Runflats - What are My Options Now in Case of Flat Tire?
So I have switched to some non-runflats about 4 months ago. And ever since then, I make sure I dodge potholes and debris left and right so as to avoid the potential flat tire since I now have no safeguard or spare and want to avoid needing to be towed just for a flat.
What would my options be as far as some type of backup or spare? Ideally, I'd like to pass on an actual spare in the trunk since space is already limited in these cars. But I still would remain open to the possibility. |
07-01-2016, 10:40 AM | #3 |
Rep 524
Bavauto sells a steel spare, ECS sells the alloy kit.
Alloy: https://www.ecstuning.com/b-genuine-...t/36112159860/ Dackel's review of the alloy: http://www.1addicts.com/forums/showp...3&postcount=27 You can also carry a small compressor, and/or a plug kit. See the sticky on this section: http://www.1addicts.com/forums/showthread.php?t=346035
'13 128i | 6MT | SGM | Black Boston | Black Gloss | Lighting | Premium | Tech | HK | Anti-Theft | [CDV-Delete | Clutch Stop | 30% Pinnacle]
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19 |
07-01-2016, 10:50 AM | #5 |
Rep 434
In terms of the compressor/plug kit...I used my girlfriend's compressor in my cig lighter (or attempted to) and the the damn thing won't power the compressor.
I was really considered that BMW mobility kit that comes with BMW's version of "Slime" and a compressor. But what's the point if the damn car won't power the compressor. |
07-01-2016, 10:55 AM | #6 | |
bimmerphile, technogeek
998
Rep 3,784
Drives: 2012 E82 6MT Sport
You can also buy an adapter for to connect the compressor directly to the battery.
07-01-2016, 11:00 AM | #7 | |
Rep 434
Thank you, I will look up the adapter option. |
07-01-2016, 01:22 PM | #8 |
Rep 524
When I get rid of my runflats, I'm planning to get this compressor:
http://www.viaircorp.com/88P.html Directly to battery is always a better solution as long as you don't buy a compressor that requires more amps than you have available to you.
Ordered 2.23 | Production Begin 3.7 | Ends 3.15 | Released to carrier 3.18 | At port 3.19 | Departed 3.23 (K-line to Brunswick) | Arrived 4.7 | Truck 4.12 | Dealer 4.19 Last edited by Mach1er; 07-01-2016 at 05:30 PM.. |
07-01-2016, 01:57 PM | #9 |
998
Rep 3,784
This is the Viair compressor that a number of us have bought: https://www.amazon.com/Viair-00073-H...keywords=viair
And the lighter-to-battery adapter: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
07-01-2016, 03:42 PM | #10 |
European Editor
10589
Rep 22,992
Best thing is to carry a full size spare(or winter tire) in the trunk. Having a mini spare is fine... until you take that cross country road trip and get a flat. That mini spare is only good for 120 miles at 45 mph. Who wants to drive like THAT! That is why I carry a full size spare on a 17" steelie & a jack kit from BMW.
07-01-2016, 05:03 PM | #11 |
Rep 505
Drives: 2010 128i 6MT Sport Pkg. 18"
I use the BMW compact donut, small generic jack and small compressor with alligator clip adapter that connects to the underhood battery connections, as I also couldn't get the interior plug-in to work. Owner's manual says all charging, jumping etc. should be done via underhood connections, not directly to the battery.
07-06-2016, 04:26 PM | #13 |
Rep 434
have you had successful use with the dynaplug before? This seems like a good option. Dynaplug, a small tool kit, and the compressor. I think that would take care of most flats at least until I fully look into the spare options posed here.
07-06-2016, 06:57 PM | #14 |
Rep 2,402
Compressor and plug kit.
I've plugged a few tires roadsideover the years, none mine fortunately. Just friends/people in need. For a really long trip, I logistically consider tossing a spare/scissor jack, etc. in the car...but often decide against it. Lot of infrastructure/rental car agencies out there should shit really hit the fan., rare as that is.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
bodega_bladerunner155.50 |
08-17-2016, 02:22 PM | #16 |
Rep 281
I would probably just go with a sealant/pump kit. In an extreme blow you would need to wait and get towed but that's fairly rare. Also inspect your tires for bubbles every couple weeks and replace tire if needed before blow happens.
