06-28-2016, 03:12 PM | #1 |
Track Whore
542
Rep 1,640
Let's talk bushings!
Alright gents (and ladies if we have any in the audience), I'm looking to upgrade the differential and front/rear subframe bushings on my E92M track car and I'd love to hear any advice, tips or opinions you have.
This car is 100% OEM suspension at the moment. Any details on exactly what specific bushings to replace while I have the car in pieces would be greatly appreciated. This is a dedicated HPDE car that has street tags, is mostly gutted but is not a race car used in competition. I appreciate the insight and thank you in advance. |
06-28-2016, 05:24 PM | #2 |
Track Whore
542
Rep 1,640
I've been sort of mulling over these:
http://www.bimmerworld.com/BimmerWor...ing-Set_2.html http://www.bimmerworld.com/BimmerWor...m-Bearing.html http://www.bimmerworld.com/Aluminum-...-1-Series.html |
06-28-2016, 05:56 PM | #3 |
Rep 979
I have turner solid diff bushings, subframe bushings, complete bimmerworld rear spherical conversion, and am about to install the front sphericals as well soon. Used to be my daily then I got tired of the stop and go and got an EV. Car is solid and extremely well connected to the ground. Btw what cage is that?
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782 |
06-28-2016, 06:09 PM | #4 |
Rep 8,076
Drives: 11 E90 M3 Individual
With solid bushings, you have to keep in mind that solid bushings will transmit loads to whatever its mounted to or in. So probably need to factor in potentially reinforcing some parts/sections of the chassis.
2018 F30 320iX Melbourne Red
06-28-2016, 06:19 PM | #5 | |
Track Whore
542
Rep 1,640
My rollbar is from AE Performance, I picked it up from jolette Any particular weak points with the E9X that need reinforcing? |
06-28-2016, 08:29 PM | #6 |
Rep 12,728
there are plenty of people with solid subframe and diff bushings running around with nothing else done. care to elaborate or share some examples?
Instagram; @roastbeefmike
06-28-2016, 09:13 PM | #7 |
Rep 8,076
I do recall seeing E90 strut tower reinforcement plates available. Solid camber plates certainly transfer load to the sheet metal.
I'd think about these areas...Rear shock mounts, spring perches, engine and transmission mounts/subframe members, and suspension attachment points I haven't seen a failure of those points yet. Doesn't mean it won't happen.
06-28-2016, 09:27 PM | #8 |
Rep 12,728
the only times i have seen the rear subframe being reinforced is when someone does a true rear coilover conversion. i really dig the way it looks and how functional it must be. i'm not saying its a bad idea to reinforce, just saying people have been running solid bushings for years without ill effect.
06-28-2016, 10:41 PM | #9 | |
Rep 8,076
Just something to keep in mind given BMW's recent track record was my point.
06-28-2016, 10:50 PM | #10 | |
Rep 979
06-29-2016, 09:32 AM | #11 | ||
Rep 6,218
06-29-2016, 09:46 AM | #12 | |
///M Powered for Life
11490
Rep 10,329
06-29-2016, 10:01 AM | #13 | |||
Rep 979
06-29-2016, 11:29 AM | #14 |
Track Whore
542
Rep 1,640
So let's see here:
Am I missing anything else that's highly recommended? |
07-03-2016, 07:26 PM | #15 |
Rep 12,728
i picked up some fall line monoballs from IND for under $400 shipped. discount code USA16 for this weekend.
07-03-2016, 10:47 PM | #16 | |
Rep 1,470
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
07-04-2016, 11:10 AM | #17 | |
Track Whore
542
Rep 1,640
07-04-2016, 12:31 PM | #18 | |
Rep 330
Getting solid subframe bushing installed tomorrow, and hope it reduces wheel hop when launching the car. |
07-04-2016, 04:01 PM | #19 | |
Track Whore
542
Rep 1,640
07-04-2016, 05:50 PM | #20 | ||
Rep 12,728
07-04-2016, 09:03 PM | #21 | |
Track Whore
542
Rep 1,640
These? |
