BMW X5 and X6 Forum 2014-Current
      06-20-2016, 11:58 AM   #1
skinsfanin1979
Drives: BMW X5
iDrive Display will not turn on!
My relatively new (at least to me) 2014 X5 iDrive display will not turn on. I quickly ran out for lunch and the display was just blank. No boot screen, nothing. The radio and Heads up Display are functioning as expected (as are parking sensors).
I got to my destination for 5 minutes and got back in my car and drove 5 minutes and still did not come back. I read another thread regarding holding the volume button down for 30 seconds so it resets but that was for a 5 series. Is there another "reset" type of functionality. These kinds of electronics failures concern me on such an expensive car. For what it's worth I took it out all weekend into the city and had no issues with the display. Another point to note is its really hot today and the display may have been out in the sun but again, I would not think that would be an issue?
      06-20-2016, 12:12 PM   #2
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Take it to the dealership, as you are still under warranty.
      06-20-2016, 12:14 PM   #3
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
Let your car sleep for 20 minutes and see if the computer reboots. The blank screen is a common problem and typically resolves itself after shutting off the car and restarting.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
      06-20-2016, 01:01 PM   #4
skinsfanin1979
Drives: BMW X5
I will only take it to the dealership if I know it is a continuing problem. Of which does not seem to be the case with electronics on a BMW (not always repeatable or self-correcting).
I'll see what happens when I get in my car in a couple hours. Hopefully it is back. As KZang mentioned I was not aware this is a common problem since it was my first time.
      06-20-2016, 03:53 PM   #5
skinsfanin1979
Drives: BMW X5
So just got in my car after it was sitting for over 3 hours and the display still won't turn on. Strange that the entertainment with radio and heads up works. The command feature to use navigation is also working and can see the directions on the heads up. It's just the display that won't work.
Any other suggestions?!?
      06-20-2016, 04:04 PM   #6
BitteEinBit
Field Marshall
32
Drives: '21 X5 M50i DHP
I would take it to the dealer.
      06-20-2016, 05:52 PM   #7
Kzang
Kzang's Avatar
3240
Yup take it to the dealer. I had my dash go out after 2 weeks ownership and mine was brand new with 3 miles on the odo. It happened twice but both times it fixed itself after a restart. Last week I brought my car in for repairs due to my steering wheel not adjusting up and down. I had to have my adjustment switch replaced due to faulty switch and reprogram the car due to the dash going out.
      06-21-2016, 08:41 AM   #8
skinsfanin1979
Drives: BMW X5
For what it's worth, turned on my car this morning and the screen started up normally. I almost wish it didn't so the issue could be diagnosed better. I will keep an eye on it and hopefully it doesn't happen again. It is concerning though if I have to go on a long ride and need the Navi and reverse camera that it may not work.
      06-21-2016, 08:44 AM   #9
Kzang
Kzang's Avatar
3240
Take it in.. the techs can run diagnostics and see that it is faulty.
      06-21-2016, 08:58 AM   #10
skinsfanin1979
Drives: BMW X5
Thanks. I know I will have to go do that.
      06-22-2016, 09:28 AM   #11
MattBianco
MattBianco's Avatar
Drives: 2015 X5 35d msport
I believe they are two different sleep cycles. One is 17 minutes long. And one is much longer. It appears this feature resets with the longer cycle. There are also threads about the cycle being impacted by how you lock and unlock the car (key fob or touch), were key is able to do more.....I have never experience this however.
The dealer will believe you. I also have a habit of taking pictures or videos of anomalies, which I have used to show the problem, but never because I was challenged (with BMW).
Amber or Red Rear Turn Signals? Vote/have your say: LINK. Post your MPGs 100L/km here: LINK X5 F15 Engines Compared LINK
Take the BMW X5 F15 Survey: LINK See the Results: LINK N57 Diesel Tuning Chips Compared LINK
      06-22-2016, 01:15 PM   #12
teodorjelev
Bulgaria
585
Drives: Mercedes AMG GT 53 4-door
There is an option to turn off the display, are you sure that we get it used?
If not, you go back in the trunk and develop several screws and disconnect the battery for 10 minutes and try again!
If so becomes, write it dead!
      06-22-2016, 05:27 PM   #13
theove
Drives: X5 4.0E
..... Last week I brought my car in for repairs due to my steering wheel not adjusting up and down. I had to have my adjustment switch replaced due to faulty switch and reprogram the car due to the dash going out.
I had the same problem with the sreeringwheel.....
xbimmers
