BMW X5 and X6 Forum 2014-Current
      06-17-2016, 03:22 PM   #1
daddymalu
Drives: M5
Digital Fuel Gauge Not Accurate
My digital fuel gauge for some reason on my X5 for some reason will not ever go to full. On a full tank the gauge is sometimes off by 3 little red lines to about 6 which is almost a quarter of a tank off. My round analog gauge works just fine. It has been like this from the beginning. I have had several BMWs with similar digital gauges and this is the first time I have ever had this issue. My dealer has told me that this is normal. This can't really be normal. The car is still safe and I never let it run near empty anyways, and I know a few people have had similar issues with the older X5s. Is there anyone else with this issue?
      06-17-2016, 03:58 PM   #2
possib1edoc
Drives: BMW X7
Have the same issue...no clue how to fix it. Figured if dealer "looks into the issue" there will probably be more harm than good done.
      06-17-2016, 04:18 PM   #3
daddymalu
Drives: M5
I also have a noticeable rattle coming from instrument cluster when driving above 60 MPH. If I hold my hand on the dash the rattle stops. Dealer also said this would be impossible to fix. I love the truck even though it has these tiny imperfections.
      06-17-2016, 05:02 PM   #4
Class5Kayaker
Class5Kayaker's Avatar
Drives: 2016 BMW F15, 2014 Porsche 991
That's not technically a fuel gauge. It's your estimated fuel range in miles or km (it doesn't display "E" through "F" it displays numbers reflecting miles or km) and it's my understanding that it takes into account your average fuel consumption. Assuming the max range on your display is 400 miles (that's what mine is), if you have a lead foot or a 50i it makes sense that you wouldn't show "full" on that gauge when you fill up since it's basing it on your average fuel consumption and giving you an estimate of the number of miles until empty.
It's just another way of displaying what you can already display as a digital number by pressing the "BC" button on your stalk. I'm willing to bet the numbers match.
2016 BMW F15 xDrive 35i - Imperial Blue Metallic
2014 Porsche 991- Sapphire Blue Metallic
      06-17-2016, 05:59 PM   #5
daddymalu
Drives: M5
I still have to say that I don't think this is normal. The x5 is actually my wife's car. I drive a 2014 m6 and in the last 4 years I have had 2 brand new 7 series all with similar digital instrument panels and my other 3 cars went all the way to full once filled.
      06-17-2016, 09:38 PM   #6
MysticBlue
Drives: '20 M5C, '09 M3 DCT Coupe
What "digital fuel gauge" are you talking about? Is this something new? Are you talking about the gauge directly under the speedometer? That's not a fuel gauge. It's a range guestimator. As mentioned above, it is a rough estimation of range measured in miles. If the tank has 20 gallons in it and your mpg has averaged 20 mpg lately, then it would read 400. If your mpg has averaged 15, then that gauge would read 300. I don't remember what the tank capacity is (maybe 22 gallons?) but I average 17 or 18 mpg and when I fill up it usually doesn't go all the way up to 400, more like 350. If this gauge you are talking about is something new on the digital dashboards, then disregard my ramblings, but mine is a MY2016.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
unluky7528.00
      06-17-2016, 09:46 PM   #7
daddymalu
Drives: M5
I am sorry for the confusion... I am talking about the gauge under the speedometer... In the other 3 BMWs I have had with this similar setup, when my gas tank is full the bar goes all the way to the right... In fact my brother has the same exact x5 and he is not having this issue... But I guess there is a possibility I am wrong and this is perfectly normal... Here is a picture the way it looks in my car... When I fill up my wife's truck I will take a picture of this as well...
      06-17-2016, 10:28 PM   #8
MysticBlue
No problem. That's what these forums are for. When comparing to your previous cars, they may have had better MPG and/or different capacity fuel tanks, so the math works out different. As far as your brother having the same X5, maybe his driving habits are different so he gets better gas mileage? If you get up near 20MPG then that gauge would go most of the way if not all the way to the right (400 miles). If your wife only gets 15MPG then I wouldn't expect it to go all the way to the right. Is it a V8?
      06-17-2016, 10:51 PM   #9
daddymalu
Drives: M5
The wife has a v6 and it is our family car and generally driven conservatively, so I don't think this theory works. Our m6 driven a lot harder than our x5 ever will be, and the bar goes all the way to the right. In both cars we do keep the auto engine shut off switch off.
      06-17-2016, 11:37 PM   #10
MysticBlue
I looked it up, 22.4 gallon fuel tank. So if you are getting 20mpg, then it should be reading over 400 miles (all the way to the right) when you fill the tank. Use the button on the end of the turn signal to see what the vehicle is calculating for mpg. So you might be right to question it. Maybe there is an issue with something that is causing it not to calculate something correctly. Unless the scale is different on the gauge for the I6 as opposed to the V8.
      06-18-2016, 03:38 AM   #11
pragueX5
pragueX5's Avatar
Czech_Republic
156
Drives: 2021 X5 M 40d mildhybrid
what you are reffering to is the estimatef mileage remaining based on your current consumption/driving style. meaning if driven hard or in heavy city traffic you will not have this gauge to full as its simply not the full mileage potential the car can do.
and for the record this is not fuel gauge, thats the round thing on your left woth the petrol tank symbol
      06-18-2016, 06:58 AM   #12
daddymalu
Drives: M5
This must be a neat mileage calculator exclusive for the x5 because it certainly does not work like this in the m6 or a 2014 750i. Most people I talk to including my service advisor think this is abnormal as well.
      06-18-2016, 07:06 AM   #13
daddymalu
Drives: M5
In my picture above the fuel tank is full. In my humble opinion the red bar should go all the way to the right and not leave 3 little red lines remaining. This is how it works in other BMW vehicles.
      06-18-2016, 07:13 AM   #14
Stinkyxy
Drives: X5
The bar is based on the mpg based on the last 20m. So if you are driving the car hard and then easy for 20m in theory it could go higher and fill the 3 bars after driving a little.
Mine doesn't go past 3/4 - all city driving.
      06-18-2016, 09:18 AM   #15
neuro0
Drives: X5
The "full mark" represent 500 miles, as each box is 100 miles. As you can see on the same picture, the digital display of your range is 466 miles, so the bar display is consistent to the digital display. You have 3 little red lines remain, and each redlibes represent 10 miles. Can't get more accurate than that.
Maverik2594140.00
      06-18-2016, 11:59 AM   #16
ixlr8
Drives: 2016 X5 35i
As others have said... it is a guesstimate of miles to empty, not a fuel gauge, with a max indicated range of 500 miles. On my '16 X5 35i, when I fill my tank, the indicator does go all the way to the right. My average fuel economy is 25.1 mpg and when I fill my tank, the guesstimate for range to empty is 580 miles. What is your average fuel economy reading??? I'm guessing about 21 mpg.
      06-18-2016, 12:56 PM   #17
cretanu
Drives: BMW X5 M 5.0d
Try to drive the last 50-100km at a very low consumption...then refill the tank fully...it will show a very high range and a full line under the speedometer!!!😉😉😉
      06-18-2016, 03:58 PM   #18
MysticBlue
Now I can see that the 35i range gauge and the 50i range gauge have different scales. That's why yours doesn't go all the way to the right... it's a 500 mile scale, as opposed to the 50i which only scales to 400. Anyway, do the math. for that gauge to ever read 500 miles, you would have to be getting over 22 miles per gallon. If you are not (I don't imagine many would unless you're on a road trip, all highway driving) then it is never going to read full scale. Simple math. Bottom line is it is doing exactly what it is supposed to do. It is up to you to understand what it is telling you.
      06-18-2016, 08:04 PM   #19
daddymalu
Drives: M5
I guess it makes sense. I wish it worked the same way across the other bmw platforms.
      06-18-2016, 09:02 PM   #20
Class5Kayaker
It does work the same across the other platforms, it just so happens that those cars you mentioned average just a little over an even hundred (400, 500, etc) on a full tank while your X5 35 averages 470 miles on a full tank right now.
      06-18-2016, 10:28 PM   #21
Kzang
Kzang's Avatar
3240
Drives: 2015 X5 35i Msport SG
OP as others have already pointed out, it's an estimate of how much mileage you will get based upon your current mpg reading.
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
      06-19-2016, 08:30 PM   #22
daddymalu
Drives: M5
I admit it. I was wrong. I did a long drive this weekend and the bar went all the way to the right. Thanks for all the help.
xbimmers
