BMW X5 and X6 Forum 2014-Current
      06-13-2016, 05:45 PM   #1
xkey
Drives: X5 2015
F15/2015 Bluetooth Low Volume
I have an iPhone 6S and native Music App worked very well for playback via bluetooth until a couple of weeks ago, and the volume started to go up/down for some reason. Now it's considerably softer than radio. I tried to play the same song,
1) Radio
2) mp3 from music collection stored on HDD
3) mp3 from iPhone via bluetooth
1) and 2) are at equivalent volume level, while 3) is about 15%- 25% lower compared 1) or 2).
By 15% - 25% I'm referring to the volume progress bar on display.
I made sure there were no other bluetooth devices in the car that may potentially interfere with the main connection. Same result.
There was an old post http://f20.1addicts.com/forums/showthread.php?t=947920, but doesn't seem to help with my problem
      06-13-2016, 07:57 PM   #2
leo95se
Drives: '09 e92 M3, '15 F15 X5d
same here. its ok with usb though
      06-13-2016, 10:15 PM   #3
Terp335
Drives: E90 2011 335i M Sport
Did you make sure the volume is turned all the way up on your phone while playing a track over Bluetooth? You didn't mention it so I'm guessing that may be your issue. It does matter and will impact your audio output significantly.
      06-14-2016, 07:17 AM   #4
nyalpine90
nyalpine90's Avatar
7433
Drives: MY24 G01 AW Msport
2016 BMW X4  [9.33]
this!
      06-14-2016, 12:11 PM   #5
MarineOh3
MarineOh3's Avatar
Drives: 2012 F30 / 2016 F15
+2
The volume on your device has to be turned up to max when using Bluetooth. USB generally makes no difference.
2012 328i Sport Line - JB on Coral Red
2016 X5 35d M Sport Line - CBM on Ivory White and Black Dakota
      06-14-2016, 06:01 PM   #6
leo95se
Yes. It's no where near the volume it should be though
      06-15-2016, 12:53 PM   #7
artem123
artem123's Avatar
250
Drives: G30
I have a somewhat similar issue. Every time when i get in the car and my iphone connects to it i am guessing in which mood my car is. Is Bluetooth is going to be very quite and i will need to crank up volume almost all the way up, to be able to hear, or in fact volume will be normal and calls will be loud enough with volume in the car to be around 2/3... Volume of the Bluetooth on a phone itself is a constant and never changes.
Ones drove a Reliant Robin. )))
      06-15-2016, 09:38 PM   #8
xkey
Drives: X5 2015
Thanks for responses. I did make sure that the volume of iPhone was turned to the maximum before comparing playing same song from different sources.
As a matter of fact, I remember that volume change on iPhone when connected to car couldn't be changed in earlier version of iOS. And it is available to be changed recently
The only thing I haven't done is to change to a different iPhone to see the difference. Will report back when get a chance
Now I need to make a case to BMW services. Is there a software that I can use to provide some quantitative evidence in terms of dB?
there is an iOS app "Measure", it might give me some numbers
      06-16-2016, 12:41 PM   #9
MarineOh3
MarineOh3's Avatar
You could also make sure that your volume limiter isn't activated on your iPhone.
Settings-->Music-->Volume Limit
All out of ideas if this doesn't work.
      06-16-2016, 02:12 PM   #10
double_j
Drives: 2008 JB/B E90 M3
Same here though I don't think it's a fault. I think the system is actually designed that way to compensate for the volume controls on the sending device and to make sure that you don't get your ears blown off when the bluetooth connects at full volume.
Not a big deal, I just turn the volume back up when I connect to BT. It seems like Radio, USB, and bluetooth all maintain separate volume settings.
      06-16-2016, 05:31 PM   #11
Doanster
Doanster's Avatar
627
Drives: 2014 F15 Carbon Black M-Sport
You said things were working fine up until a couple weeks ago, right? What changed, whether car was updated/coded or app/OS updates on your phone?
A little mod here, a little mod there...
      06-17-2016, 10:10 PM   #12
xkey
Drives: X5 2015
Yes, the X5 seems to be deteriorating ever since I bot. Last 30 days, I've noticed at least 4 times where the entertain system just rebooted while I was driving. The first time it happened, it did scare me a bit, as I was in middle of road. Luckily it doesn't affect driving at all.
This is so weird, but it has not happened last 5 days yet.
      06-19-2016, 12:15 AM   #13
Rmshawla
Drives: 2016 X5
Do you still get audio notifications (text, email, etc) over bluetooth, or even from the iPhone itself once you're in the car? I have the iPhone 6 I think and once I'm in the car, I receive no audio notifications - for example if I get a text message or an email, the phone only vibrates. The bluetooth connection to the car seems to circumvent the audio notifications. I asked the BMW genius at the dealer if he knew what the story was and just thought Android pairs better, but didn't have a solution for me. Anyone?
      06-19-2016, 09:01 AM   #14
leo95se
mine has always been that way too. you get notifications if the car is set to media. the phone wont override radio/satellite.
xbimmers
