06-07-2016, 05:16 PM | #1 |
Stop the hate, get a V8
3850
Rep 8,625
Do I need to bleed the brakes after every track day?
Car: 2011 M3 sedan with ZCP
Tires: Yokohama AD08R Front brakes: StopTech ST40, slotted rotors, SP pads Rear brakes: OEM rotors, SP pads Fluid: SRF After my first full track day on the StopTech kit, I noticed that there's a little bit more pedal travel now when driving around town. Did a bit of air really get into the system after just one track day, and if so, do I need to rebleed them with fresh SRF before the next track event? I understand from a performance perspective that having the freshest fluid possible is a good thing, but I'm still surprised that after just one full track day there is already a different feel to the pedal. Also, is there anything special to know about bleeding the ST40 caliper?
Past: 2011.5 M3 sedan ZCP |
06-07-2016, 05:22 PM | #2 |
Track Whore
542
Rep 1,640
Did you boil the fluid?
How much material did you shed from the pads? I always bleed after every event and flush once a year, but that's me. It's the only thing stopping the car at 130+MPH so why risk it? |
06-07-2016, 05:41 PM | #3 |
Rep 4,488
I've never bled with SRF, just flush annually, and that's not an uncommon practice with SRF. A bit of pedal feel change at the end of a track day is normal and totally fine. It won't keep getting worse.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
06-07-2016, 06:09 PM | #5 |
Rep 1,711
No need to bleed with SRF flluid. I flush it once a year and never have problems.
However, if you just installed yout BBK, installation of new calipers and brake lines introduces a lot of air in the system. I remember, when i did that, i had to flush many many times untill i got all the air out. So make sure your brake system is free of air |
06-07-2016, 06:21 PM | #6 | |
3850
Rep 8,625
Nope, brakes were consistent all day long. We had 5 30-minute sessions with an hour of downtime between. Ambient temp was about 70 in the morning and 80 in the afternoon. Unsure how much pad wear there was, I haven't had time to measure. I live in downtown Chicago and it's tough to work on the car here. I will take the first session cautiously this Friday evening. I have an extra bottle on hand in case I need to bleed the lines at the track.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 06-07-2016 at 06:33 PM.. |
06-07-2016, 06:58 PM | #7 |
Rep 6,218
How much more pedal travel do you have? Might be because pad thickness or type of pad. I've noticed this even though internetz swear it's not a reason.
06-07-2016, 07:05 PM | #8 | |
3850
Rep 8,625
I too assumed "less pad material, therefore it has to travel further". Everyone I talked to has said that's baloney and the piston location adjusts with pad wear. Dave Zeckhausen said the change in pedal feel means there are air bubbles. I should probably pull the pads and inspect them. One theory is that they glazed or something, which might feel like less stopping power.
06-07-2016, 09:51 PM | #9 | ||
Rep 6,218
If you have full pads at full fluid the piston doesn't have to press as much. As the pad wears down the piston doesn't retract as much assuming the edge of the pad is always the same distance to the rotor as it wears down? (I butchered the choice of words but you get the picture). Can someone explain? Because when I swap back in new full track pads it feels instantly better - that's why I never understood this. And when I put in stock pads it feels different too (initial bite because material?)
06-07-2016, 10:02 PM | #10 | |
3850
Rep 8,625
Dave Zeckhausen's answer to me was: The pistons don't travel any further in and out as the pads wear. Instead, the level of fluid in your reservoir drops over time and the pistons' new "home base" is slightly further extended than it was when the pads were new. But the piston location adjusts with pad wear, so there's no increase in piston travel. The longer pedal is due to air bubbles being compressed.
06-07-2016, 10:03 PM | #11 | |
Rep 4,488
The pedal travel and initial bite difference between different has to do with differences in the compounds. I don't know the technical details around that.
06-08-2016, 12:01 AM | #12 | |
Rep 6,218
-regarding compounds i think it's just a "grabby" vs "modulateabler" compound lol
06-08-2016, 07:45 AM | #13 |
Rep 145
If this was your first DE you were likely on the brakes longer than you should have been. Pretty common for folks new to DE's. You might have boiled the fluid or over heated the pads. Do you have another set of pads to swap in and check?
06-08-2016, 08:16 AM | #14 |
3850
Rep 8,625
Wasn't my first DE. It was the first full day on those brakes and the new AD08R tires. I did not have any change in brake feel over the course of the day, so I don't think the pads or fluid were overworked.
06-08-2016, 08:51 AM | #15 |
Skittles, OT OG
2337
Rep 649
I thought I was going crazy. I feel like I have way more pedal travel with the PFCs. I was going to bleed the brakes tonight thinking that might be the issue.
06-08-2016, 10:28 AM | #16 | |
Track Whore
542
Rep 1,640
06-08-2016, 11:16 AM | #17 |
3850
Rep 8,625
Yep, understood, but this fluid is barely two months old and has only seen one full track day. The car isn't even a DD, it sits in the garage most days.
06-08-2016, 11:22 AM | #18 |
Rep 742
Give a few more days. I've noticed sometimes that immediately after a track weekend, the pedal might feel a little softer, but goes away after a few days. If after a week it still feels a little soft, then as others said, probably with a new BBK, might need another bleed, just because it's a new system. But no, if you are running SRF, you should NOT need a bleed after a single day, and in fact, shouldn't need to bleed all year.
I just had Fall Line rebuild my Stoptech fronts, and they mentioned it would likely be a good idea to do one more hot bleed after putting a few miles one them, I'm thinking due to the air introduced by the reinstall.
2011 Jerez Black/Fox Red E90 M3 DCT, ZCP, ZCV, ZCW, ZP2, BMW Apps
2015 Golf R |
06-08-2016, 01:10 PM | #19 |
Rep 638
I personally think SRF is waste of money. I've used them for past year or so, but I had to bleed them after every event, just as I had to with RBF - no tangible difference in performance nor longevity, yet double the price. I'm going back to RBF.
If you get your brakes hot enough, you need to bleed before every event. Everyday within an event may not be necessary, but YMMV. |
06-08-2016, 01:20 PM | #20 | |
Rep 4,488
06-08-2016, 11:25 PM | #21 |
Rep 2,224
I always bleed them before going to track. Even if its just an egg cup each. The front lines always bleed out a bit dirty. I use 600 race fluid
06-09-2016, 08:01 AM | #22 | |
Rep 4,488
