06-02-2016, 02:25 AM | #1 |
Rep 493
Draining windscreen washer reservoir, how?
I got some wrong liquid in the windscreen washer reservoir and tried to drain it by siphoning with a flexible tube.
No luck, as there are too many kinks from filler to reservoir. Is there a draining plug or another trick, beyond just emptying it with the electric screen washer pump? BTW, what is the capacity of the reservoir? |
06-02-2016, 06:47 AM | #2 |
Rep 97
I did this to my Acura, find the motor and remove it. Usually twists off. I ended up needing a new motor when my mishap happened. Acura part was about $30 so I can assume the BMW one is $120 haha
06-02-2016, 07:14 PM | #3 |
Mmmmm…
1150
Rep 2,426
Drives: F15
You'll need to drain it or remove the fill hose part and then siphon it out.
06-02-2016, 08:58 PM | #4 |
Rep 18,717
The tank is sitting behind the passenger side fender.
You may want to try take a peek from the fender liner.
06-03-2016, 04:52 AM | #5 | |
Rep 493
I still have to find a simple way to drain it... I promise to post here a rare Himalaya flying picture if a reasonable suggestions to drain this reservoir is submitted - thank you in advance, whoever! |
