| 05-30-2016, 07:12 PM | #1 |
![]() 31
Rep 66
Question for any techs, stutter during start up for a corolla
Hey guys, so i've been trying to diagnose a slight problem with my friend's car and was wondering if i could get some help. So its a 2008 toyota corolla. The car stutters a bit when starting up. It'll be like....crank, crank, crank, sputter, then fires right up. Once started, it runs/idles fine and doesnt sputter. Only during the start up process. It gets worse the longer it sits, but it also gets better the less it sits (ie running a few errands, it gets better each time its started as long as it doesnt sit too long). Now, so far we've not experienced any no starts. Just a slight stutter. I changed the spark plugs which were very corroded but problem still persists.
Thinking it might be the fuel draining out of the rail, i primed the fuel pump but problem still persists. I assume if i prime the pump and problem still persists, then the pressure regulator should be fine since that acts as a check valve and we dont think the fuel is draining out. I may be wrong tho.... The only thing i can think of is to change the fuel filter and clean out the fuel system including injectors. With the exception of running a fuel pressure test, any ideas? Thanks in advance! |
| 05-30-2016, 08:13 PM | #2 |
Rep 3,793
Drives: 2018 M2
Rod Bearings
| 05-31-2016, 08:59 AM | #4 |
Rep 3,793
Drives: 2018 M2
| 05-31-2016, 09:01 AM | #5 |
![]() ![]() 4375
Rep 6,202
Could be low fuel pressure. How many times did you cycle the pump before starting it?
Could also be a leaky injector. Let it sit overnight and then pull the plugs. |
| 05-31-2016, 10:45 AM | #6 | |
![]() 31
Rep 66
And...lol @ ejt86...scared me Edit: pardon my ignorance, but since this isnt a direct injected car, would i still be able to smell fuel on the plugs after i let it sit over night? |
| 06-04-2016, 12:38 AM | #7 |
2JZ-GTE
3561
Rep 4,490
Sounds like a problem with the VANOS system, typical on the 2008 Corolla's
| Bookmarks |
