BMW X5 and X6 Forum 2014-Current
      05-21-2016, 02:06 AM   #1
lalaura
Drives: E90
BMW F15 coding instruction
Re-Code for Dazzle Headlights (LED Adaptive Headlights like EU-Spec):
Change FA (VO) to Remove 5AP & 8S4 from VO. Save and Write FA to Vehicle
VO Code BDC Body Module
Read FA(VO)Activate FA(VO)Read SVTRight-Click ECU & Select Code
VO Code KAFAS2 Module or FLA2 Module
VO Code FLE (43) Module
VO Code FLE (44) Module
Now Proceed to code FDL Changes to both FLE(43) & FLE (44) Modules (below)
Once all above is completed, you can proceed to code any FDL Changes to the other ECUs listed above, as VO Coding is completed in those ECUs.
Re-Code for Enhanced Bluetooth:
Change FA (VO) to Remove 6NH from VO & Add 6NS to VO
VO Code HU_NBT
Now Proceed to code HU_NBT Module … or re-code if coding was already present
IF YOU NEED TO DO EITHER OF THE ABOVE … FOLLOW THE INSTRUCTIONS FOR “HOW TO CHANGE FA” in my BMW f series Coding Guide. This needs to be done FIRST … meaning before you perform FDL Coding or Changing Werte Values
ACSM Module:
SeatBelt Reminder Lights OFF: set all to nicht_aktiv
3000Gurtzustandsanzeige_Beifahrer_GFW_GZA_BF
3000Gurtzustandsanzeige_Fahrer_GFW_GZA_FA
Disable Welcome 3 Gongs:
3000 Initialwarnung_GWF_IW = nicht_aktiv
SeatBelt Reminders/Sound OFF: set all to nicht_aktiv
3000SBR_PreWarning_Fahrer
3000SBR_PreWarning_Beifahrer
3000SeatBeltReminder_SBR_Fahrer
3000 SeatBeltReminder_SBR_Beifahrer
BDC_BODY Module:
Auto Start/Stop OFF by default
3023TCM_MSA_DEFAULT_OFF set to: aktiv
Auto Start/Stop – Remember LAST Setting
3023TCM_MSA_MEMORY set to: aktiv
Unlock all doors with engine off (Single-Pull Handles):
3040 VAM_UNLOCK_KL15OFF_AFTER_PIA_AUTO_LOCK set to: aktiv
Electronics off when door opened
3020TCM_LOGIC_R_OFF_DOOR set to: aktiv
Close Mirrors/Windows/SunRoof from FOB or CA – set all to: aktiv
3056KOMFORTSCHLIESSUNG_FB
3056KOMFORTSCHLIESSUNG_PA
3110ASP_BEIKLAPPEN
3110ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN
3110ASP_BEIKLAPPEN_NACH_KOMFORTSCHLIESSEN
Set Mirror Fold Delay Time
3056KOMFORT_SCHLIESSEN set to werte=00
Start Car by pushing button (hold brake not needed)
3020TCM_STARTLOCK_BRAKE set to: nicht_aktiv
3020TCM_STARTLOCK_DRIVINGREADINESS set to: nicht_aktiv
Tilt Passenger Mirror farther down when in reverse
3110ASP_BORDSTEINAUTOMATIK_DELTA set to: werte=4B
Opening FRONT doors won’t interrupt windows:
3050FH_TUERAUF_STOP_MAUT set to nickt_aktiv
Opening REAR doors won’t interrupt windows:
3051FH_TUERAUF_STOP_MAUT_REAR set to nickt_aktiv
Fog Lights stay on w/ High Beams
3068NSW_AUS_BEI_FL set to nicht_aktiv
Ambiance Lighting controlled independent from Dimmer Switch
3070 AMBIENTE_NACHFUEHRUNG set to: nicht_aktiv
High-Beam Assistant – Auto-On:
3068FLA_AKTIVIERUNG set to: LDS_in_A_oder_2
Increase Angel Eyes Brightness to 100%
Xxxx MAPPING_STANDL_V_L_PWM_LEVEL_1 = 100%
Xxxx MAPPING_STANDL_V_R_PWM_LEVEL_1 = 100%
Xxxx MAPPING_PARKL_V_L_PWM_1_LEFT = 100%
Xxxx MAPPING_PARKL_V_L_PWM_2_RIGHT = 100%
Change Mirror Un-Fold Automatically at XX Speed (Binary value in Werte):
3110 ASP_GESCHWINDIGKEIT_AUTO_AUSKLAPPEN werte=14 (12Mph)
Change Triple-Blink Count to another Value:
3068 BLINKZYKLEN_ANZAHL_TIPP – Werte = # blinks-1 (4 blinks = werte=3)
Turn on Brake Force Flashing with Hard Braking:
3068 ESS_AKTIVIERBARER_AUSGANG = bremsclicht blinkend
Turn off Amber Side Markers next to Headlight:
3063 MAPPING_SIDEMARKER_L_OUTPUT set to: OFF
3063 MAPPING_SIDEMARKER_R_OUTPUT set to: OFF
Enable Illumination of Exterior Door Handle LEDs when in Reverse
3070OVT_BEI_REUCKFAHRLICHT set to: aktiv
Turn on Fog Lights with Welcome Lights:
3063 MAPPING_NEBELSCHW_L_PART_OF_WL set to: werte=01
3063 MAPPING_NEBELSCHW_R_PART_OF_WL set to: werte=01
Activate Rear Fog Lights: (In conjunction with REM Module coding)
3068 NSL_Verbaut = Verbaut
Disable Headlight Washers
3080 WW_SCHEINWERFERREININUNG set to: nicht_aktiv
Auto Light Sensitivity Increase
3130RLS_DEF_FLC_SCHWELLWERT_SATZ set to: option below
3130RLS_FLC_SCHWELLWERT_SATZ set to: option below
Options:
normal = mornal
empfindlich = sensitive
sehr_empfindlich = very sensitive
unempfindlich = insensitive
Turn On Tail Lights with DRLs:
3063 MAPPING_TAGFAHRL_1_V_L_OUTPUT = tfl_l
3063 MAPPING_TAGFAHRL_1_V_R_OUTPUT = tfl_r
3063 MAPPING_TAGAHRL_2_V_L_OUTPUT = werte=04
3063 MAPPING_TAGAHRL_2_V_R_OUTPUT = werte=04
Activate Rear Fog Lights feature for lighting switch:
3063 Mapping_Nebelschlussl_L_output = nsw_l
3063 Mapping_Nebelschlussl_L_Function = nebelscheinwerfer
3063 Mapping_Nebelschlussl_R_output = nsw_l
3063 Mapping_Nebelschlussl_R_Function = nebelscheinwerfer
FLE (43) & FLE (44) ECUs (must completed coding in both ECUs:
Euro LED Anti-Dazzle Headlight Coding (part 2):
3003 Stadt_V_Idx set to: F015Wert
3003 SAE_Idx set to: F015Wert
3003 H_plus4_Idz set to: F010Wert_SA552_US
3003 Blendfreies_Fernlicht_Idx set to: F015Wert
3003 Volles_Fernlicht_Lichthupe_Idx set to: F015Wert
HKFM_LS Module:
*** May take up to 30 minutes to begin working after coding ***
Close/Open Rear Hatch from Fob & Kick Panel
3010SCH_FBD set to: aktiv – werte=01
3010SCH_TOEHKI set to: aktiv – werte=01
3010TASTER_FBD set to: aktiv – werte=01
HU_NBT or HU_CIC Module: (Not all available in CIC Headunit)
3000HIGH_BEAM_ASSISTANT set to: aktiv
Set cell phone ringer as primary
3001INBAND_RINGING set to: aktiv
Enable Siri Voice Control
3003CE_DEVICE_SPEECH_RECOGNITION set to: aktiv
Disable Auto-Locking of Doors once begin driving
3000DOOR_LOCK_AFTER_DRIVING_AWAY set to: nicht_aktiv
Enable Sports Displays
3000EFF_DYN_SPORT_CID set to: aktiv
3000EFF_DYN_SPORT_UNIT set to: aktiv
* To change units displayed to be ft lb and hp
KOMBI3008DREHMOMENT set to: lb_ft (displays ft lb)
KOMBI3008LEISTUNG set to: ps (displays hp)
Enable Turn Signals in HUD
3001HUD_TURNSIGNAL set to: aktiv
Change Navi Voice to British English
3000LANGUAGE_ENGLISH_UK set to: master
3000LANGUAGE_ENGLISH_US set to: nicht_aktiv
Video-in-Motion activated:
3000 SPEEDLOCK_X_KMH_MAX werte = FF
3000 SPEEDLOCK_X_KMH_MIN werte = FF
3000 VIDEO_HANDBRAKE set to: nicht_aktiv
3000 VIDEO_FRONT_LOCKED set to: nicht_aktiv
3000 VIDEO_SPEEDLOCK_CONDITION set to: none=00
Navi Trip-Import
3000NAVI_TRIP_IMPORT set to: aktiv
Navi Fuel-Stop Proposal Along Route
3000NAVI_FUELSTOP_PROPOSAL set to: aktiv
Enable Video Files from USB
3000ENT_CODEC_XVID set to: aktiv
3000ENT_CODEC_XVCD set to: aktiv
3003API_USB_VIDEO set to: both
Add GPS Current Location to Navi Menu Items
3000NAVI_POSITION_MENU set to: aktiv
Add Turn-Signals to HUD
3000HUD_TURNSIGNAL set to: aktiv
Enable the function of saving video files to NBT Hard Drive for play later
3000 ENT_MC_VIDEO_SUPPORT set to: aktiv
Disable Office Function Speed Lock-Out
3000 OFFICE_MESSAGES_SPEEDLOCK_CONDITION set to: nicht_aktiv
Enable Full Text Lines in Office While Driving
3003 PIM_DRIVING_TEXT_LENGTH set to: whole text_07
Disable Audible Chirp/Beep When Locking Car
3000 ACOUSTICAL_LOCK_CONFIRM set to: nicht_aktiv
Enable Speeach Input for E-Mail or SMS
3003 SPEECH_2_TEXT set to: aktiv
Enable Time-Stamp Display for Call Log
3003 TIMESTAMP_DISPLAY set to: aktiv
Add Temperature & PSI to tire monitor screen
3001RDC_SAFETY set to: aktiv
Disable Legal Disclaimers
3001LEGAL_DISCLAIMER_TIME set to: kein_ld
3001MACRO_CAM_LEGALDISCLAIMER set to: kein_ld
3001MACRO_NIVICAM_LDISCLAIMER set to: kein_ld
Change i-Drive Animation to ///M Logo
3001STARTUP_EMBLEM set to: variant_01
Enable IPCE Web Server @ 172.16.222.1
3000IPCE_WEBSERVER set to: aktiv
Enable WiFi Hot-Spot
(Need to install a DLNA/UPnP media sharing server on your laptop or phone to be able to use this)
3000ENT_MC_WLAN_STREAM_DMP_COVERART set to: aktiv
3000ENT_MC_WLAN_STREAM_DMP_VIDEO set to: aktiv
3000ENT_MC_WLAN_STREAM_DMP set to: aktiv
3003WLAN_STATUS set to: aktiv
3003WLAN_MODUS set to: ap
3003WLAN_SIGNAL_STRENGTH set to: outdoor
Enable Developer Menu
3000 ENTWICKLER_MENUE set to: aktiv 01
IHKA Module:
A/C System Remembers Last Setting
3000OFF_MEMORY set to aktiv-werte=01
Always Remember Air ReCirculating
3000MEMORY_UMLUFT set to: aktiv
KAFAS2 Module:
3050FLA_ON_OFF set to: aktiv – werte=01
KOMBI Module:
Show Digital Speed in MPH in Cluster
3000BC_DIGITAL_V set to: aktiv-werte=01
Show Turn Signals in HUD
3008HUD_PIA_BLINKER set to: aktiv
3000BLINKER_HUD_ENABLE set to: aktiv
Enable GPS-Sync for Clock
3000GPS_UHR set to: aktiv
PMA_PDC Module:
Enable Rear-View Camera at all Speeds
300BD_SCHWELLE_2_KMH set to: Werte = FF
300BV_SCHWELLE_2_KMH set to: Werte = FF
http://bmw-f-coding.blogspot.com/
xbimmers
