      05-20-2016, 08:05 PM   #1
Widowmaker
Widowmaker's Avatar
Drives: 12' 135i Alpine White n55 DCT
ESR 18x9.5 fitment questions
Looking at these specifically
http://www.wheelplususa.com/wheels/E...r+Machined+Lip
Looks like they offer those with an:
18x8.5 et 30
18x9.5 et 35
If I ran the 18x9.5 for all 4 wheels
will I need to run 225/40/18 and 255/35/18 to get a "nice" fit
Can I run oem sizes 215/40/18 and 245/35/18? I'm not sure on the 9.5 width on the front
      05-21-2016, 05:15 AM   #2
John_01
John_01's Avatar
Australia
232
Drives: E90 325i, E82 135i
For the rear, ET35 is too aggresive for a 9.5" rim. Its going to cause a lot of problems without major fender work.
For the front its not realistic to use a 9.5" rim width with anything that looks like stock fenders.
Normally offsets for the 1 series are ET45 front and ET50 for the rear.
      05-21-2016, 08:37 AM   #3
Widowmaker
Widowmaker's Avatar
Damn, ok my fenders are rolled pretty aggressively (basically a flattened lip)
I have seen images online of ESR wheels on 135i's that look to have stock fenders, most ESR wheels are built all to the same specs ie, offset, wheel width, etc. So I am wondering then how are those guys running these wheels
      05-22-2016, 12:18 PM   #4
Eyeman
Eyeman's Avatar
121
Drives: 2008 135 blk, blk, step
You'd have a much better chance getting it to fit using the 8.5s up front. Then both your fronts and rears would be 10mm too close to your fender. So you could gain 10mm through running undersized tires, or gain 10mm through camber. And btw, to gain 10mm on the outside of the tire, you'd need to actually go 20mm smaller overall. Basically small running 215s tires up front and 235s in the rear with 2 to 3deg front and rear camber would do it, sort of, if you are into the stretched/cambered look.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
      06-28-2016, 12:19 PM   #5
MuNkY6913
The Crowing
MuNkY6913's Avatar
Drives: BMW 135i
2009 135i  [8.00]
i ran a 9.5 wide +45 offset in the rear with 255 tires on my car for about a year and a half. I am also lowered an inch. they did rub on very big dips or bumps. I also ran +35 offset in the front. with 225 tires i believe. search for tsw wheels and you should be able to find my thread. never had a problem with the front at all.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback
1addicts
