04-29-2016, 11:19 AM | #1 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Steering wheel shake/vibration
How often do the OEM rotors become warped, asking because Iv had this vibration/shake in my steering wheel that I cant find the cause for.
3 sets of different wheels in different sizes same vibration, same wheels with new rubber and road force balance same vibration. Starts when I hit about 70-80, worse at times than others. Sometimes its almost totally gone. Since its not wheel balance what could it be other than a warped rotor?
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
04-29-2016, 11:41 AM | #2 |
Rep 2,361
next step is look at suspension
wheel bearing tie rods If you're only experiencing vibration when braking, then get a set of track pads, run them for a week in traffic and switch back to your regular pads. |
05-01-2016, 02:08 PM | #3 | |
Rep 1,017
Hmm alirght ill take a look at tire rods and bearings.
05-01-2016, 02:53 PM | #4 |
Rep 24,730
Spacers ?
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
05-01-2016, 03:14 PM | #5 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
Looks like you have checked the simple things to check. What suspension are you currently running?
05-01-2016, 06:12 PM | #6 |
Rep 1,017
05-01-2016, 08:46 PM | #8 |
Mr. Nice Says Hello
636
Rep 16,662
How many miles on the car? I would look at the condition of your top mounts.
05-01-2016, 09:02 PM | #9 | |
Rep 3,736
Drives: 2018 M2
05-02-2016, 01:28 AM | #12 | |
Rep 1,017
Hubs are clean, scrubbed them down good when I painted the centers black for the volk wheels. Will inspect the rest of the culprits everyone pointed out though!
05-02-2016, 04:03 AM | #13 | |
Rep 891
05-02-2016, 04:55 AM | #14 |
Rep 6,285
Can you hear the noise or just feel it through the steering wheel?
Is it still there above 70-80? Have you tried checking the car out by jacking it up and seeing if there is any play in the sussy by pulling the wheel or spinning the wheel and feeling it for a vibration or hearing any grinding noises (bad wheel bearing) |
05-02-2016, 04:57 AM | #15 |
Rep 6,285
05-02-2016, 08:40 AM | #16 |
Rep 127
I have the same situation right now, starts shaking on the freeway at 60 mph. Stealer said it could be from the car not being balanced, but I doubt that that is causing the vibration. Please let me know when you find out!
05-02-2016, 12:01 PM | #17 | |
Rep 1,017
05-02-2016, 12:54 PM | #18 |
Rep 1,171
Just throwing it out there my old MB W210 had vibration around 40mph and the solution was trying different thickness driveshaft shims. No idea if it applies here but just a thought if you run out of things to check.
05-02-2016, 11:03 PM | #19 |
Rep 1,017
Doubt thats it, had this before and after I put in my CF one piece drive shaft which deletes the rubber guibo and puts in a much thicker metal adapter plate.
05-03-2016, 12:40 AM | #20 |
Rep 6,726
Do you have the right lug nuts on the car, running studs?
If it's only happening during braking, it's typically deposits. If it's happening at higher speeds but not while braking, it's something with your suspension and or connected bits to your suspension. |
05-03-2016, 01:58 PM | #21 | |
Rep 1,017
If not I need to get an alignment anyway so can have BMW techs take a peak while its in air.
05-03-2016, 02:07 PM | #22 |
Rep 1,017
Alright, jacked it up one side at a time. Wiggled both front wheels hard, pulled on them and spun them.
Passenger side was solid as a rock zero movement no grinding when spun. Driver side had a very slight movement when I pulled hard on 1 side or tried to wiggle back and forth, think I may of heard a slight sound as well. Was very sleight but being on driver side as well as how senistive this car is this may be the culprit.
