      01-06-2016, 08:04 AM   #1
HazeD
Drives: 135i
Smile 18x8 best tire fitment?
What's up guys, I'm new to this forum but not to the bmw scene. I'm attempting to do a daily/track set up and I need some suggestion from you guys.
18x8 +42 offset all around
245/35R18 all around
continental extremecontact dws 06 is the tires I want to go with for the moment. Any rubbing issues?
Planning on rolling front fenders slightly more, rears are already rolled aggressive because my current set up is
19x9.5 +45(F) 19x10.5 +50 (R)
225/40R19 275/35R19
Car is also lowered on h&r sport springs, no camber plates. Don't remember my alignment specs
      01-06-2016, 02:28 PM   #2
John_01
John_01's Avatar
Australia
232
Drives: E90 325i, E82 135i
You are probably going to need some camber plates for the front. The rear will be close. I guess the rear might fit if you can run generous rear camber. The low springs don't help though.
      01-11-2016, 05:38 PM   #3
dbronnik
dbronnik's Avatar
223
Drives: N54 E88
That's about right. Front will be close without camber and rear might need a fender roll and/or trim.
Source: I previously ran ET40 square setup, which is pretty close to ET42 (2mm worse).
1addicts
