10-22-2015, 05:47 PM | #1 |
Rep 21,753
▀▄ eas | Dinan Engine performance Complete Line Up - Authorized Dealer
Now available from EAS is Dinan's complete line up for the M5. As an authorized dealer we are ready to handle all your Dinan needs whether it be install or shipping. PM today for expert advice and info Dinan - Free Flow Stainless Exhaust System - BMW F10 M5 Dinan’s Free Flow Exhaust System features 100% stainless steel construction measured to exact specifications to ensure proper fit via factory hangers and mounting points. Dyno tuned for maximum exhaust flow with minimum backpressure, this system is designed to provide a more aggressive sound under acceleration, while reducing drone inside the vehicle, thanks to Dinan’s exclusive Helmholtz Chamber and Butterfly Valve technologies. The exhaust gasses exit through larger laser engraved ultra durable satin black (or polished) ceramic coated quad tips. Features: - Quad 3.5" laser engraved polished (or black) ceramic coated exhaust tips with Dinan logo - Improve performance by 8 horsepower - Throaty, deeper sound - 100% 304 Stainless Steel Construction - Helmholtz chamber to remove drone - Incorporated Butterfly Valve technology - Simple installation using high quality BMW clamps and hangers - Straight through" canister design Models Supported: 2012+ BMW F10 M5 Dinan - Carbon Fiber Cold Air Intake - BMW F10 M5 The F10 M5 Dinan® high flow carbon fiber cold air intake, like most Dinan products, has a sleek and functional appearance that embodies high performance. The F10 M5 cold air intake allows cool outside air to be pushed into the engine via a pair of supplemental carbon fiber intake ducts located at the front of the engine bay. The M5 cold air intake system was carefully designed within tight packaging constraints and in consideration of ideal aerodynamic diffusing angles to optimize the efficiency and performance of this induction system. Each duct leads combustion air through a custom designed intake assembly that has a larger than stock metered air flow housing, as well as a Dinan conical air filter with a 77% larger capacity. Dinan engineers have painstakingly developed custom tooling to ensure the entire Dinan cold air intake system is sealed like a factory replacement, thereby preventing hot air from the engine compartment to compromise its effectiveness. The stock air inlets are left intact and fully functional to provide a new total of four air intakes into the engine for maximum airflow. Improved induction airflow offered by Dinan cold air intake systems increase engine performance, even more so if used in combination with other performance enhancing Dinan products. Features - Maximum peak power of 693 HP and 651 lb-ft of Torque utilizing Dinan Stage 2 components (DINANTRONICS™ Performance Tuner, intake and exhaust). A difference of 13 HP and 7 lb-ft of torque from Dinan Stage 1 (D-TRONICS Performance Tuner Only). - Dinan proprietary Injection molded Dinan MAF housings are larger than stock - Stock air filters are replaced with 77% larger Dinan conical air filters. - Entire Dinan Intake system is sealed like a factory replacement to ensure only cold outside air and not hot air from the engine compartment is being utilized. - Stock System Stays Completely Functional - Carbon fiber air box lids and intake ducts - Raised Dinan logos are laminated into the carbon fiber intake - Rubber hoses, mounting brackets, & hardware included. Models Supported 2012+ BMW F10 M5 Dinan - Stage 2 Performance Tuner - BMW F10 M5 The DINANTRONICS™ Performance Tuner is a highly engineered and sophisticated piece of computer hardware and software that enhances engine performance, without negating or voiding your new car warranty coverage and without affecting long term reliability or the functionality of on-board diagnostic systems. It is also the only tuning device emissions legal in all 50 states. The ultimate objective of developing this piece of technology was to provide the ability to control every signal entering and exiting the BMW factory Engine Control Unit. These items are unique to Dinan and together they embody the apex of performance engineering in a powerful, reliable, and warrantied package. Drivability There is more to a tune than just cranking up the boost. Power needs to come on smoothly and in a predictable way to make the car as fun to drive at wide open throttle as cruising around town. It is your BMW, but reborn with new found acceleration and speed. Installation We install everything we sell (and more) at our 8,000 sq/ft, three lift facility in Anaheim, CA. Our experienced technicians are armed with an arsenal of specialty tools to get the job done right. Contact us for an estimate or to schedule your installation! Easy To Use Dinan's ECU is Bluetooth® Smart meaning that you can change maps simply via a Bluetooth connection. Just install and you are done! Designed for the Future The DINANTRONICS™ Performance Tuner was engineered with future expansion of functionality in mind. Boasting the most powerful processing power on the market the DINANTRONICS™ Performance Tuner can handle more functions and processes than any of its contemporaries. To that end the Dinan performance tuner is capable of interfacing with the CAN and FlexRay communication systems which allow for controlling powertrain functions, among others. This means that when new functions are developed there will be no need for a new box, just a short software update at your local Dinan dealer. Models Supported 2012+ BMW F10 M5 Ordering: Phone: You can reach us directly by calling 866.669.0705 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday - 9AM-2PM PST Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
10-28-2015, 05:39 PM | #2 |
Rep 21,753
Thanks for the inquires
PM today for all your Dinan needs
10-29-2015, 01:27 PM | #3 | |
Rep 313
Will it work for me? What is the price? |
10-29-2015, 02:17 PM | #4 |
Rep 21,753
PM coming your way
10-30-2015, 01:39 PM | #5 |
Rep 21,753
Dinantronics in stock and ready to ship
PM today for pricing and details
11-04-2015, 03:13 PM | #6 |
Rep 21,753
Thanks for the inquiries
Dinantronics in stock and ready to ship PM today for pricing and details
11-11-2015, 01:59 PM | #7 |
Rep 21,753
Get your Dinan engine performance from EAS today
PM for pricing and details
11-16-2015, 04:24 PM | #8 |
Rep 21,753
Get your Dinantronics from EAS today
In stock and ready to ship/install PM for pricing and details
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 11-16-2015 at 04:36 PM.. |
12-15-2015, 12:38 PM | #9 |
Rep 21,753
Dinantronic units in stock and ready to ship out
12-24-2015, 02:00 PM | #10 |
Rep 21,753
Dinantronics units in stock and ready to ship
12-29-2015, 03:36 PM | #11 |
Rep 21,753
Get your Dinan Performance from EAS today PM for pricing and details
01-07-2016, 11:23 AM | #12 |
Rep 21,753
Dinantronic units in stock and ready to ship same day
01-21-2016, 05:49 PM | #13 |
Rep 21,753
Dinan exhaust ready to ship
PM today for all your Dinan products and questions
01-27-2016, 02:33 PM | #14 |
Rep 21,753
Dinantronic's in stock and ready to ship same day PM for pricing and details
02-01-2016, 01:31 PM | #15 |
Rep 21,753
Dinantronics ready to ship same day
PM today for all your Dinan engine products
03-21-2016, 06:44 PM | #16 |
Rep 21,753
All spacers sizes in stock and ready to ship PM today for pricing and details
04-18-2016, 02:53 PM | #17 |
Rep 21,753
Dinatronics in stock and ready to ship PM today for pricing and details
04-20-2016, 02:58 PM | #18 |
Rep 21,753
Dinantronics ready to ship out PM today for pricing and the full Dinan line up
05-05-2016, 02:01 PM | #19 |
Rep 21,753
PM today for all your Dinan performance
05-25-2016, 06:23 PM | #20 |
Rep 21,753
PM today for Dinan inventory and pricing
06-10-2016, 06:47 PM | #21 |
Rep 21,753
