07-06-2015, 11:41 PM | #2 |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Not me
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
07-07-2015, 09:59 AM | #3 |
Rep 984
Every manual BMW I've owned I've had this happen to me every once in a while. It's driver error, nothing else.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
07-07-2015, 06:32 PM | #5 |
Joint Chiefs of Staff
4918
Rep 115,980
07-07-2015, 07:01 PM | #7 |
Rep 2,818
I don't usually go WOT in 1st a lot but when I do I have yet to experience a grinding going into second at ALL in my F80. I never had it happen to me in my 2013 E92 335i either. Only in my Hondas/Acuras lol.
07-08-2015, 01:05 PM | #9 | |
Rep 12,310
BMW MT's don't like to be rushed like that through the first couple of gears.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
07-08-2015, 02:14 PM | #11 |
You got my money?
3156
Rep 4,646
Drives: Ice Cream Truck
My E92 does this. My four STI's did not, nor did 3 integras and two hondas before them.
This IMO is a BMW thing that you have to work around.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
07-08-2015, 09:14 PM | #13 |
Rep 334
The clutch is fully on the floor, I've owned manual cars my entire life. I'm 6'7" trust me I've got long legs, its fully on the floor. If I'm shifting fast it does it. It only does it in second no other gear.
07-09-2015, 12:40 AM | #14 |
Rep 2,926
Drives: Cayman GT4, 135i
Get a clutch stop
Current: M2CS
Gone but not forgotten: Cayman GT4, M2C, 2011 135i, E83 X3 6MT, 2016 SO M3, 2012 335iS, 2010 135i and 2006 e90 325xi |
07-09-2015, 07:32 AM | #15 |
High on Acceleration
671
Rep 1,439
Are you sure you aren't hearing the ebrake bracket grind against the driveshaft? I can punch it in 2nd and it will sound exactly like a gear grind all the way to redline...perhaps you are getting that momentarily when you shift into 2nd.
The current fix is to bend the ebrake bracket but I'm waiting until there is a solution to replace or rebalance the driveshaft because I believe that is the problem and I don't want to be stuck with replacing a carbon fiber driveshaft outside of warranty... |
07-11-2015, 12:12 AM | #16 |
Rep 113
happened to me at first, then i adjusted how i drove the car, i dont "powershift" 1-2 shifts anymore...its a quick but i care more about it being safe then quick. then 2+ i can powershift through no issues
John Schroeder
2015 M3 4DR - SSII, 6sp, HK www.JDS-Photos.com @JDS_Photos-instagram @JDS-Photos - FB |
07-11-2015, 06:52 PM | #17 |
Rep 27
I'm having a feeling this might be bad synchros... I've driven manuals for quite a while ( Since I was 18, I'm 22 now.) and I've only ran into this problem In my 350z which was known for having back synchros in certain gears.
07-12-2015, 09:29 AM | #19 |
Rep 158
Bring it back to dealer and have it check.
07-12-2015, 12:16 PM | #20 |
sudo su -
52
Rep 236
My E92 335i has done this as long as I can remember. I have learned to avoid shifting quickly from first to second under heavy accel. Interesting to hear the F80's still do it.
07-21-2015, 10:40 PM | #21 |
Rep 1,753
My E90 M3 did this, it sucks and kills the fun.
I was hoping they fixed this with this new tranny, but I guess not. Glad I am ordering DCT this time around.
18? Camaro 2SS 1LE
16' M3 MG Ext. /SO Int. (DCT, Ohlin R/T, 19" wheels) 15' Audi S4 13' Audi TTRS (APR stage 1, MSS springs) 09' C6 Z06 08' M3 Interlagos Blue: 6sp, Tech. |
07-24-2015, 02:38 PM | #22 |
Rep 979
Not normal at all.
My E90 USED to do this, turned out the syncros were shot. Dealer replaced my transmissions and I quickly switched to Redline transmission fluid and what do you know? Second gear grind GONE. If the grind was normal, then this issue would be happening again, it does not. OP, switch to another tranny fluid, IMO the stock fluid is too thick and does not allow for proper slip of syncros. On a side note, I shift from 1 -> 2 near redline and I have a CAE shifter, so there is added stress there as well. Butter smooth every time.
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782 |
