05-27-2015, 02:37 AM | #1 |
Rep 525
Combox retrofit coding clarification
Hey, so I'm planning to retrofit my combox this week into my 2010 e87 (build date 01/10).
I thought i understood how to code the retrofit but after reading a lot of posts on ********* in the last couple days i'm more confused than ever. I thought it was simple VO update and recoding CIC and combox modules as well as changing my production date to 03/11, but then i read things about .ssd vin coding and that's where i've become stuck. So here's some info on what i have in my car: - I retrofitted and coded myself the CIC iDrive with a USED CIC computer and hardwired emulator to activate the navigation. --> i know that the CIC computer came from a car with a combox because before i coded it for my car, i had the "bluetooth audio" option under CD/Multimedia - I have an MULF only (no TCU), I don't have BMW Assist - I have the 6FL usb/aux in from factory - I have purchased a Brand New Combox Media Module. - I have purchased a plug and play retrofit harness from Kufatec I understand how to physically install it, but i need some pointers on coding My understanding is: 1. change production date to #0311 2. Add $6VC, $6NR, $6NF to VO, Write to CAS and NFRM 3. Recode CIC, and Combox modules Am i on the right track? Is there something else i need to do? I'm not to fussed on getting BMW Apps and Connected Drive working for the moment as i will probably need an FSC code, it's just when i go to install the combox this week, i can have the system working as it should with bluetooth audio streaming. |
06-02-2015, 05:29 PM | #2 |
Rep 155
Is the combox connected properly?
Is the MOST loop "complete"? Does the combox show up in NCS? |
06-03-2015, 08:10 AM | #3 |
Rep 3,547
What you describe is a method of coding I've seen recommended but I've never done it that way. What I've always done is download the module where the parameter I want to change is located, modify it, and then upload that module (all in NCSExpert). I've only done a few things, digital speedometer (without the BMW "correction"), doors lock on speed, top goes down if the door open button is held a few seconds, windows go up if top raise button is held a few seconds (I don't have comfort access). For these things, I know it works without changing the "vehicle order".
I believe what you describe also works if done properly.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
06-03-2015, 11:28 PM | #4 |
Rep 525
Hi guys thanks for your reply, yes i got it working about a week and a bit ago and so far it's working properly. I only had an MULF and no TCU so i didnt have an extra most connection that needed termination. The plug-and-play harness i got from kufatec worked 100% except the connector didn't actually fit (i just removed the connector "housing" and plugged it in directly if that makes sense)
I just tried the same stuff as when i did my cic retrofit: Change production date to 03/11 Add the following options: $614, $615, $644, $6AL, $6FL, $6NF, $6VC, $6NR, $7SP to the VO but i did not write it to CAS or FRM Then recoded CIC and MEDIA So bluetooth AD2P is working, internet through bluetooth tethering is working except i get a "This service is not available in your country" message. Anyone know how to get around that? But 6NF/6NR BMW apps are not working...(didnt really expect it to because my combox was brand new) Do you guys know anyone that can import an FSC Code for me? I emailed bimmertech about 2 weeks ago but havent gotten a reply. |
06-04-2015, 09:34 AM | #5 | |
Rep 525
