05-14-2015, 08:59 PM | #1 |
Rep 2,358
WARNING!!! JB4 can damage your cars electrical system if handeled improperly
To all current owners of a JB4!
The JB4 installation manual has been updated with the following warning: "Also be very careful when working with the BMS USB cable as it sits close to the battery rail which is a live +12v connection. Allowing the USB cable to touch the +12v connection WILL damage the JB4 and MAY damage the TMAP sensor wiring requiring the ground bypass at the bottom of the guide to be performed. Wrapping a piece of cloth tape over the battery rail connection and/or USB connection will help prevent accidental damage"
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
05-14-2015, 09:16 PM | #3 | |
Gone Fishin’
7318
Rep 12,125
05-14-2015, 09:48 PM | #4 | ||
Rep 3,051
2022 RAM TRX
2021 Ford Bronco 2022 BMW M3 |
05-14-2015, 10:41 PM | #5 |
Rep 2,358
I used the OLD manual to install my JB4 back around July 2014. Looks like BMS also knew about the risk back then, just not very good at highlighting it.
I now a faulty DME/TMAP ground wire, or whatever it is, because of this that I will need to resolve with a BMS workaround/patch to avoid a ~2000usd repair at BMW Hope that I can prevent others from the same fate by posting this!
(A Dane in China) |
05-14-2015, 11:55 PM | #6 | |
Rep 286
OP sorry this happened to you. Best of luck getting it corrected. |
05-15-2015, 12:14 AM | #7 | |
Rep 2,358
(A Dane in China) |
05-15-2015, 12:20 AM | #8 | ||
Rep 286
I don't know your background with cars but not taking any precautions to avoid shorts on an exposed cable is bad practice no matter the application. |
05-15-2015, 02:13 AM | #10 |
Rep 597
As many have said before, this is old news. Also leaving your USB in your engine compartment isn't suggested. I believe putting the USB end in a bucket of water may damage the JB4 as well. I didn't see that in manual. Hopefully Terry will update it But seriously, I think many people don't know what can happen if you touch it to your 12v. another interesting experiment is to take a metal coat hangar and touch it to both the positive and negative leads on the battery. A welders gloves/apron and a face shield would be appropriate attire. (this happened to me a long time ago, the coat hanger melted in less than a second. scary stuff.
05-15-2015, 06:12 AM | #12 |
Joint Chiefs of Staff
4918
Rep 115,980
Yes this is at the top of every JB4 F Series install guide and should be in every tuner guide.
Always disconnect the battery when working with live electrical systems and be careful not to let the USB cable or any other harness connection touch the battery rail when the battery is reconnected. Mike |
05-15-2015, 07:17 AM | #14 |
Rep 483
Let's not jump on OP, especially considering he owned his mistake and did the service of warning other people whether they know about this or not.
We all have different levels of technical expertise, and most people overrate their technical expertise, thus can get in over their head very quickly. My motto has always been to learn from other people's mistakes, but if they don't let us know what they are, then there are less learning opportunities. |
05-15-2015, 09:44 AM | #15 |
4918
Rep 115,980
Also worth noting as this same post has been uploaded to every forum, the risk to damage the TMAP sensor ground is only present on 2012-2013 F Series 335 pneumatic wastegate systems. The EWG board, like that used on the S55, and 2014+ F series 335, uses a different configuration and power supply. In those models the risk is only to the JB4 itself.
Mike |
05-15-2015, 09:58 AM | #16 | |
Rep 13,001
... and this warning has been announced since Benjamin Franklin.
05-15-2015, 11:02 AM | #17 | |
Rep 3,407
http://f80.bimmerpost.com/forums/sho....php?t=1127208 http://f80.bimmerpost.com/forums/sho....php?t=1127209 http://f80.bimmerpost.com/forums/sho....php?t=1127206 Service of warning others? Really? Nonsense like this is why rookies like himself have "heard that the JB4 causes issues." If you lack the intuition and basic common knowledge on what does what under the hood of a car, perhaps more entry-level piggyback solutions better suited for beginners is right for you. |
05-15-2015, 05:02 PM | #18 |
Rep 984
This thread = lol
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
05-15-2015, 05:36 PM | #20 | |
Rep 2,336
JB4 is not a entry level PB? Pros only? haha
05-15-2015, 05:58 PM | #21 |
Rep 3,407
The BMS Stage 1 or other units by shops which cater to those who are new to modding might be a better solution. If it's your first rodeo and you don't know what a battery terminal is or are unaware that it's best to disconnect your battery before working on the car, maybe a JB4 isn't right for you yet.
It's best to start small and work within your abilities. |
05-15-2015, 06:20 PM | #22 | |
Rep 3,583
Drives: 2017 M3
2017 F80 YMB, ZCP, ZEC, ZLP, DCT. Production Date: 7/15/16
