05-11-2015, 11:49 PM | #1 |
Rep 116
2012 135i idrive red screen
Hi has anyone encounter this issue with there idrive ? Basically I just start the car up and it just stay on red screen.
I try to turn off the car and start again same issue. I also try turning off the idrive by pressing the volume knob but it still stuck on a red screen. Anyone got any ideas ? |
05-12-2015, 08:49 AM | #2 |
Rep 3,550
05-12-2015, 11:30 AM | #3 | |
Rep 116
05-12-2015, 10:56 PM | #4 |
Rep 14
I messed up the finish on my screen and had to remove it to polish it to be even a couple weeks ago. There are two connectors attached to the screen, one "round", another which is more square.
I turned the car on and forgot to connect the "round" cable and my screen was red. I've read about people having these issues and my guess is it's something to do with a loose cable (I'm not sure where the other end connects, it might be worth looking into). Let me know if you have any questions, it's fairly easy to remove the screen. |
07-07-2015, 11:30 AM | #5 |
Rep 142
Idrive RSOD
Same thing just happened to me this AM. Car was in the garage all weekend long. I turned on the car, and at first the iDrive page came on just fine, but when i connected my iPhone the screen went blank. I restarted the car again, and got this "red screen of death" and then iDrive went dead (I can still play the radio). I'll try turning on the car again this afternoon after work (hopefully this is just a fluke).
Did you end up taking your car to the dealer? I'm curious what the diagnostic was. thx! Last edited by DuckCoverRoll; 07-07-2015 at 11:42 AM.. |
07-07-2015, 07:19 PM | #6 | |
Rep 116
I think it's some sort of bug crashed and needed a long hard restart. |
07-08-2015, 01:10 AM | #7 |
Rep 142
Yep - same here! I started up the car when I left work, and everything works again. I'm chalking this up as an aberration. Thx!
07-24-2016, 09:30 PM | #8 |
Rep 2,049
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
just had this happen too....looks like letting it sit for a while fixes it?
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021 |
07-25-2016, 08:25 AM | #9 |
Rep 638
ditto;
now mine is a 'vert, and had the top down and it was bloody hot all the features worked, and I was worried, RECLAIMER advised me to leave it off. and after about 30 minutes it was fine, although I did have the top back up and the AC on full blast Now when I park the car with the top down I have a small cloth I put over the idrive RECLAIMER advised me it could be a bug fix and possibly need a software update but so far so good |
07-25-2016, 08:29 AM | #10 |
Rep 638
07-25-2016, 10:11 AM | #11 |
Rep 2,049
So just to add to this:
Mine happened at night, when the car was sitting in a parking lot. It was 75 degrees out...The car was driven prior to that for =/> 0.5 miles...mine def was not related to heat...Im guessing bug...
08-23-2016, 08:23 AM | #12 |
Rep 638
been told this is a software update
mine was heat/bright direct sunlight related (as top was down) |
