05-10-2015, 04:32 PM | #1 |
Rep 1,275
3er's Stock Dyno Run
Dyno Run - Stock In anticipation of having my Dinan Stage 1 tune installed in two weeks, I wanted to get a few dyno runs to establish a baseline. From a recommendation on this forum, I visited Eurocharged Performance today and came away with some great stock numbers. We did three runs and I netted the best numbers on the 3rd and final run. All runs were performed in 5th gear, sport plus, and DSC inactive. Today was 82 degrees Fahrenheit with 67% humidity near sea level (Houston). After seeing the numbers, it’s just crazy to think that my car is putting out more horsepower and torque at the wheels than BMW claims at the crank! I’ll have dyno runs performed after the Dinan install to see the gains. Also, I took several other pictures of some cars, so enjoy! 1st Run: 437.15 WHP, 419.68 WTQ 2nd Run: 438.27 WHP, 416.76 WTQ 3rd Run: 441.71 WHP, 422.34 WTQ
2019 ///M5 Competition
On Order: 2023 ///M3 Competition xDrive Last edited by 3er; 05-12-2015 at 08:39 AM.. |
05-10-2015, 04:53 PM | #3 |
Rep 1,275
On Order: 2023 ///M3 Competition xDrive |
05-10-2015, 04:53 PM | #4 |
Currently Driving
269
Rep 1,426
Drives: BPM tuned '13 AW ZCP E92 M3
Dynojets usually pump out higher numbers than Mustang "heartbreaker" dynos. Solid baseline numbers for 100% stock. It will be nice to see the numbers after the Dinan install.
05-10-2015, 04:58 PM | #6 |
Rep 1,749
Ok clearly this is abnormally high so it's good you got a baseline otherwise dinan numbers would be inflates. I have come to really love the s55 power curve. A real masterpiece right to redline
05-10-2015, 05:33 PM | #7 |
Rep 487
Nice #s. You have to remember a dyno is a tuning tool. Your #s are slightly high but every dyno is different and conditions change things as well. Its good you got a baseline. Just make sure you go back to the same place once you do your mods to check gains. Also the "STD" correction will also bump #s up a bit as well which is what Eurocharged is using.
05-10-2015, 06:07 PM | #8 |
Gone Fishin’
7318
Rep 12,125
Naa about the same as cars are putting down here on dynojets and 93 stock.
05-10-2015, 06:10 PM | #9 |
Rep 887
Nahh if you take a look around, all stock #'s are near 410-420 whp never 440 lel.
05-10-2015, 06:14 PM | #10 |
Gone Fishin’
7318
Rep 12,125
05-10-2015, 06:20 PM | #11 |
Rep 1,749
What I'll never get is why people want tunes that destroy that perfect power curve. That's traditional M. peak power to redline. I've been driving on stock tune and stock or ess linear have by far been my favorites. Will be interested to see how custom jb4 doing
05-10-2015, 07:07 PM | #13 | |
Rep 487
Nobody is runing anything. They are just going faster adding a tune |
05-10-2015, 07:19 PM | #14 |
Joint Chiefs of Staff
4918
Rep 115,980
Nice runs..
For all those commenting just remember the delta is important not the absolute number when comparing modifications. Clearly this is one of the highest stock curves I've seen but thats irrelevant when comparing.. Its great you got the baseline. Any chance you have the uncorrected curve? Mike |
05-10-2015, 07:29 PM | #15 | |
Rep 1,275
05-10-2015, 07:40 PM | #17 |
Rep 1,515
Drives: Ever changing fleet
Great numbers and a completely normal looking curve for the S55. It's funny when people post of 38X whp dynojet dynos of their S55 with a jagged power delivery and talk about how everything was working correctly on the dyno, when it is clearly obvious that isn't the case.
Here's mine for comparison also. Note the exact same shape of the curves (all my runs done in 4th gear). image by glmmd81, on Flickr And SAE: image by glmmd81, on Flickr
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
05-10-2015, 07:40 PM | #18 |
Rep 1,275
BTW, the graph states "CF: STD Smoothing: 5." Therefore, I'm pretty sure it's using STD correction. Regardless, I'll have Eurocharged confirm.
On Order: 2023 ///M3 Competition xDrive Last edited by 3er; 05-10-2015 at 07:50 PM.. |
05-10-2015, 07:46 PM | #19 |
Rep 1,515
Looks like AW 6MTs dyno nicely
05-10-2015, 08:18 PM | #20 |
Rep 122
How do you covert 441 WHP to bhp and 422 wtq to tq? I'm not even sure its possible/accurate way to do this, just curious. great post 3er, hope you enjoy stage 1!
05-10-2015, 08:32 PM | #21 | |
Rep 1,275
Thanks for the kind words! I'm excited to see what the stage 1 tune does! EDIT: Using the correct calculation (# / 0.85) would be 519 HP & 496 LB/FT.
On Order: 2023 ///M3 Competition xDrive Last edited by 3er; 05-11-2015 at 06:40 PM.. |
05-10-2015, 08:33 PM | #22 | |
Rep 1,275
