05-06-2015, 10:15 AM | #1 |
Rep 1,025
JB4/BMS stage 1 install question
For those that have done this, I have a couple of questions.
The main question is how in the world is it possible to do the MAP sensor install? I unbolted the overflow reservoir and moved it, but it became clear that even if I disconnect the hose, there would be zero chance of fitting my hand down there to reach the plug. I'm not sure I could even fit my wrist in there if I had no hands. It's extremely tight. And getting a screwdriver in there and turning it to lift the tab seems pretty much impossible. Did others remove anything else to get access? Also, is disconnecting the battery necessary, or is it sufficient to just keep the wires away from the terminal? I did it last night, but it was sparking as the trunk light was on, and it seemed more risky than not touching it at all.
2017 F-type SVR Black/black
2017 Nissan GTR Red/black 2022 BMW X5M MBB/SO Gone but not forgotten: '12 X5M, '07 AM SuperVantage, '05 Boxster S, '01 BMW M3,... |
05-06-2015, 10:30 AM | #3 | |
Joint Chiefs of Staff
4918
Rep 115,980
http://f80.bimmerpost.com/forums/sho...41&postcount=3 Mike |
05-06-2015, 01:37 PM | #6 |
Rep 6,589
05-18-2015, 09:04 AM | #12 |
Gone Fishin’
7318
Rep 12,125
I can install JB4 in stage 1 configuration in 15 minutes with this tool. All I have to do is pull back the weather stripping on the firewall, loosen the two T25 screws on the reservoir, and pull it up out of the rubber grommet. I DO NOT REMOVE THE COOLANT HOSE. Use the tool to grab the lip on the very back of the plug and should be simple to click it in.
The tool is well worth the $11 if you plan on doing JB4 install/removes by yourself. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 |
05-18-2015, 10:11 AM | #13 |
Fitness Gene
1114
Rep 2,413
Drives: 2018 M4
Garage List 2006 bmw m5 [10.00]
2016 bmw z4 35is [8.33] 2000 bmw m5 [10.00] 2018 BMW M4 [10.00] 1987 BMW 325 Conver ... [10.00] |
Effective 11 Min Home Workouts????? No equipment????? 20 years of experience Spartan Race winner PROtrainer! Click the link?? https://www.youtube.com/c/FitnessGene |
05-19-2015, 08:05 AM | #15 |
4918
Rep 115,980
There are many different techniques you can use. Once you get it once you will figure it out pretty quick. Second time will be a breeze if you ever have to remove / re-install.
All the above tools / tricks are great advice. Mike |
