04-27-2015, 06:51 PM | #1 |
Rep 2,105
Drives: M4 MW/SO 6MT, E46 M3 AW/IR 6MT
Macht Schnell Valve mod vs. "Unplug mod"
So guys im confused if these two are messing with the same valve or if the car has more than 2 valves which are being affected...
I know if the valves/flaps on the muffler are open and you unplug it, it stays open forever. Other cases show guys buying the Macht Schnell and opeining/closing valves through the turn signal handle... QUESTION: Are both "mods" controlling the same valve/flap which is on the muffler? (if so, i guess i can see the convenience factor of opening/closing with a push of a button versus unplugging a plug for free) ...Or is there another valve in the exhaust system that can be opened/closed by purchasing a valve controller Feedback would be appreciated
MILA | E46 BMW M3 | AW/IR | 6MT | KW V3 | CSL | Vorsteiner |
EMILY | F82 BMW M4 | MW/SO | 6MT | M Carbon Ceramic Brakes | M Performance Exhaust | |
04-27-2015, 07:08 PM | #2 |
Rep 246
Drives: 2015 BSM M4
Depends on how much control you want, both do the same thing and control the same valves. The MS and the JB CAN Flap module (which is cheaper) allow you to close the valves if for some reason you want them closed like morning cold starts or at highway speeds to reduce drone.
If you want to be wide open all the time then unplugging is the most cost effective method. Those modules also clear CEL if you are running DPs and the JB module has other features like disabling active sound. |
04-27-2015, 07:11 PM | #3 | |
Rep 2,105
04-27-2015, 07:30 PM | #4 |
Rep 981
If you're looking to get a tune I'd just get the JB4. I felt wrong paying a good portion of the JB4 cost to just control the exhaust valves.
You could leave them disconnected for a few days/ weeks and you should know if you'll want the control the modules provide you with. |
04-27-2015, 07:33 PM | #5 | |
BimmerPost Supporting Vendor
8274
Rep 18,859
You can unplug the valves if you want the exhaust to be open all the time and simply have no desire for operation from the driver's seat, the choice is up to you.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
04-27-2015, 09:01 PM | #6 |
Rep 1,275
Can anyone offer insight as to what the Macht Schnell module has over the JB CAN Flap module to justify the cost difference? If I'm not mistaken, doesn't the Schnell module also tap into some wires?
2019 ///M5 Competition
On Order: 2023 ///M3 Competition xDrive |
04-27-2015, 09:07 PM | #7 | |
8274
Rep 18,859
The MS EVC also has a low power mode, which allows the module to enter sleep mode to prevent any unnecessary drain while the car is locked/stored.
04-27-2015, 09:20 PM | #8 | |
Rep 1,275
04-27-2015, 09:21 PM | #9 |
8274
Rep 18,859
I'll have a DIY going up later this week, some exciting things happening.
