      04-25-2015, 08:08 PM   #1
ALEJANDRO
Drives: White 1M 2012
best gasoline for 1M in USA?
Hi guys,
I'm driving tomorrow from Mexico to the US. I was wondering what would be the best gasoline I can use for the baby M?
thanks
      04-25-2015, 08:23 PM   #2
The Wind Breezes
Drives: 135i N55 DCT
You'll have a hard time going wrong with gas in the States. 91 octane should be fine if you're in a place like California with no 93. Even if you're tuned for 93 the ECU will compensate safely for the slightly lower octane.
      04-25-2015, 10:21 PM   #3
de85275
de85275's Avatar
Drives: Valencia Orange 424/740
Also stick with Tier 1 stations, Shell, Chevron, Exxon
      04-26-2015, 09:26 PM   #4
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
If you want to avoid ethanol, which most gas in the US contains, check out this link:
http://pure-gas.org/index.jsp
Most of the stations near me that carry ethanol-free gas only have 91 octane.
I usually get 92 octane with "up to 10% ethanol" from the brand names, Shell, Chevron or Exxon as mentioned above.
Through that website, I discovered a self service Pacific Pride station 2 miles from my house that carries Sunoco 100 octane ethanol free race gas.
      04-26-2015, 09:41 PM   #5
IEDEI
Drives: L'Orange
2011 BMW 1M  [8.40]
i honestly don't think there's any difference between branded and unbranded petrol in the US.
i usually get 93 octane from Gulf or Hess stations here; and all of them have Ethanol added (have never seen Ethanol-free in the NYC/LI area).
Most stations in an area are supplied with the same gasoline. There have been numerous studies done that have found that unbranded stations have the same quality of stuff as branded stations so i think you should be fine if you get 93 octane anywhere (or 91 if that's not available to you)
      04-26-2015, 11:20 PM   #6
///BYU
///BYU's Avatar
Drives: AW 1M
I would also add BP to that list. And you may see Exxon as Mobil or ExxonMobil.
Have a fun drive. You should post pictures and let us know about your trip!
      04-27-2015, 07:19 AM   #7
Acidblast
Acidblast's Avatar
23
Drives: VO 1 Series M Coupé
the owners manual for the 1M recommends BP in the USA
      04-27-2015, 07:29 AM   #8
MightyMouseTech
MightyMouseTech's Avatar
4338
Drives: 13 135i 6MT LeMans Blue MSport
Yes, there is.
http://www.toptiergas.com/
      04-27-2015, 08:09 AM   #9
1&done
1&done's Avatar
Drives: 2011 VO 1M
I have been told by a reputable tuner that the Chevron w/ Techron helps keep our injectors clean.
///1M #643 of #740
      04-27-2015, 08:43 AM   #10
CarJunkie
CarJunkie's Avatar
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
All of a region's gasoline comes off a pipeline that all companies use, so yes, the actual gasoline is the same, but then some companies add their additive and detergent package for each market. That is the difference.
I still debate 91 octane clear-gas versus 92 octane with ethanol. Not sure which one the car likes better. It DEFINITELY likes the 100 octane clear gas, which I put in for my recent track day. Throttle response was noticably better from the moment I left the gas station.
      04-27-2015, 08:50 AM   #11
MightyMouseTech
4338
All these people running E85 mixes makes me think that running E10 is no big deal. I just go for the highest octane from a top tier station. Here in Ontario that means using Petro Can 94, even if it has ethanol.
It is the additive package that makes the difference, can be 25% of the fuel.
Saying they are all the same because the base fuel is the same, is like saying a McChicken is the same as a coq au vin from a Michelin restaurant because they both start with chicken.
      04-27-2015, 08:56 AM   #12
cmark8
M52, M62TU, S50US, S54, S65
cmark8's Avatar
75
Drives: E90 M3 6MT, E36 Touring MT
I run an E70 blend on a daily basis. I have a fuel-it LPFP kit so I'm worry free (for now). But even if you're running a stock LPFP you shouldn't be worried about the LPFP or the HPFP causing problems if you're running E10. Definitely go for top tier gas stations.
1995 E36 M3 USA / 2002 E46 M3 SMG / 2008 E90 M3 6MT
1996 E36 328i Touring 5MT / 1998 E36 323Ti M Sport 5MT
2002 E39 540i Protection
      04-27-2015, 09:58 AM   #13
Acidblast
Acidblast's Avatar
23
I've been told by multiple service techs in Ontario to use Shell v-power as it is cleaner.
      04-27-2015, 10:37 AM   #14
MightyMouseTech
4338
It is not cleaner. Shell 91 is just ethanol free. That is what I use in my bike, as it requires premium, but does not adjust for higher octanes like our cars, also, storing a vehicle with ethanol fuel over the winter is a really bad idea, gums things up.
I use 94 octane for better power and FE in the car.
      04-27-2015, 10:40 AM   #15
Jay-K
Jay-K's Avatar
Indonesia
384
Drives: Slow
yes,
I was wondering why sometimes in LA I only see 91 max?
"Well, there's a straight-six engine at the front, a manual gearbox in the middle and drive goes to the back. That's Page 1, Chapter 1 from the petrosexual handbook" - JC
      04-27-2015, 09:40 PM   #16
ALEJANDRO
thank you guys, this is a really interesting topic.
1addicts
