03-20-2015, 08:19 PM | #1 |
Rep 21
Rolling back problem
Hi everyone,
I just realized today that my 35d rolls back when brake is not applied on uphills (moderately steep) even with D gear. Today is the first time I actually realize this and I don't think it was like this before. Is this normal? Thanks in advance! |
03-20-2015, 08:36 PM | #2 |
Rep 5,066
I think this is normal since it would be very bad for the transmission gear to hold your 4800 lbs SUV while your brakes are not applied. I would utilize auto hold to remedy your concerns.
03-20-2015, 09:33 PM | #3 |
Rep 781
03-20-2015, 09:53 PM | #4 |
Rep 525
Yepp , it bothers me too , my old LincNavigator never roll back , without any "Premium Autohold " it's really sucks .
03-20-2015, 10:30 PM | #5 |
Rep 1,752
My guess is, it's part of the fuel saving structure they implemented on F15. I don't remember my E70 rolling back, but then again it's idle rpm was higher compared to F15.
I haven't tested my X5 on a steep hill (how steep are we talking about) but the rollback should actually be limited, I don't think it would continuously roll backwards at a steady speed. I always thought it would compensate the rollback (if it becomes excessive) by adjusting the idle rpm (or un-accelerated D rpm). I think Auto-Hold is a gift, most of my traffic lights are long, I love being able to just move my feet back and relax like I am sitting my couch and let the vehicle stay where it is without moving about. I didn't use auto-hold for a whole year when I first got a BMW thinking it would spoil me and I would end up rolling and rear-ending vehicles if I got another car without auto-hold.
03-20-2015, 11:05 PM | #6 |
Rep 3,307
It shouldn't roll back if you apply the brake then let off, it should hold without auto hold on (that's more for stop and go traffic, I believe, as it works even on level ground..). But are you saying you never even applied the brake at all? I'm pretty sure you have to engage the brake at least for a second before it will hold on the hill for you.
03-20-2015, 11:30 PM | #7 |
Rep 286
chrisny is right. If you tap at the brakes to bring the car to a complete stop at a slope, upon removing the foot from the brakes, the X5 should NOT roll back immediately. This is a feature found in my X5 - as I'm sure it is in every X5 - called "Hill Start Assist". However, if you let the car roll to a stop against a slope without actually stopping it with the brakes, it will not engage the Hill Start Assist & will begin to roll backwards.
03-21-2015, 12:18 AM | #8 |
Rep 5,066
Hill start assist is on my E70 and was on my E60 cars as well. But the hill start assist only holds the car for a few moment allowing you to let off the brakes and drive off without rolling backwards.
03-21-2015, 09:39 AM | #9 | |
Rep 21
I haven't tested how far the car rolls back (because I was scared to hit something in the back), but I think that it would just continue if I don't hit the break. |
03-21-2015, 09:42 AM | #10 | |
Rep 21
03-21-2015, 09:43 AM | #11 | |
Rep 21
03-21-2015, 09:55 AM | #12 | ||
Rep 3,307
03-21-2015, 10:26 PM | #13 |
Rep 286
OK, I woke up really early today (it's Sunday here in my neck of the woods), and I thought I'd help 80386i out with his predicament. So, the "official" test results, as verified by Wobbles :
The Hill Start Assist will hold the car from rolling back for 2 - 3 seconds, and after that, it WILL roll back. At least that's what it does on my car Hope that helps! |
03-23-2015, 04:14 PM | #14 | |
Rep 1,752
This was scary and I blame you guys.
I got up on a ramp to my parking lot, xDrive status indicated 8 degree incline with total %14. So I come up half way to ramp, I stop accelerating, without touching the brake pedal I come to a full stop and it starts rolling back, to a point where it rolls back as if it was in Neutral. Then I hear warning chimes and it says secure my vehicle for rolling, and I hit brake. I noticed that the shifter switched to Neutral, it may have done that to prevent damage to drivetrain, but that's extremely unsafe. At that point, if you hit gas, it will keep rolling back and it was rolling pretty fast too. Once I made the rolling stop, it did not let me switch into Drive. I tried putting it in Park then switching to Drive, did not work either. I had to put it in Park, stop the engine, start the engine again, then it allowed me to shift it into Drive. I was going to do more tests, but I had someone coming up behind me, and I didn't want to roll back into and possible over them like a giant boulder in Takeshi's Castle. I will test this again tomorrow by applying brake and coming to a full stop mid-ramp and see if it behaves differently.
03-23-2015, 08:14 PM | #15 | |
Rep 286
Try it again (when the coast is clear) with depressing the brake pedal in coming to a full stop - and then you'll see the car holds for about 3 seconds |
03-24-2015, 10:56 AM | #16 |
Rep 1,752
You are right about holding, but no, it doesn't hold for 3 seconds, it's more like 1.5 second, probably because the ramp was too steep.
I tried, it holds just fine and there should be no reason for X5 to roll back if you came to a stop, then let go of the brake, it gives you enough time to hit the gas before it starts rolling even at a %15 incline. I'll conclude it works as designed, except I have nothing to compare against, if other vehicles actually hold when you never touch the brakes.
03-24-2015, 03:49 PM | #17 | |
Rep 21
03-24-2015, 03:51 PM | #18 | |
Rep 21
03-24-2015, 11:26 PM | #19 | |
Rep 1,752
Maybe we should do some tests in Reverse. I can stop on same steep hill going down, put it in reverse, go back a little then let go of gas to see if it holds or rolls forward under same conditions (1 with Brake applied then let go, 2 with just letting go of gas)
03-24-2015, 11:35 PM | #20 |
Rep 286
Just a wild thought here, but could it (the rolling back behavior) have anything to do with our new ZF-8 transmissions and the way those things are designed?
03-27-2015, 01:53 PM | #21 |
Rep 1,752
On same steep ramp,
In reverse, it actually holds much longer and it rolls forward much slower, takes a lot of roll before it speeds up, although I did not let it roll all the way down until it switches to N. I also did not hit the gas as much because I don't think the Reverse gear is all that strong in X5.
03-31-2015, 04:59 AM | #22 |
Rep 774
My x5m50d doesn't roll back and stays that way as long as I want it to. If I dont brake, it slowly rolls forward or stops in a hill, no rolling back. If the engine does auto stop, the car rolls back a few cm, before engine starts, but thats it, auto h not engaged.
Tags |
roll back, transmission |
