03-01-2015, 03:19 PM | #1 |
Rep 3,990
My Issues :(
So, as you all know, my suspension was removed. While driving in the highest setting, I got a chassis stability malfunction. This caused the car to not turn off with two button pushes. It would actually turn back on with the second button push. The suspension is back to stock with ZERO errors in the iDrive. This is the behavior as follows:
1) When I push the start button once, it will keep radio and gps on (despite me coding the ability for the gps and radio to turn off when I open the door), and only shuts off completely when I lock the car. 2) When I have returned - I guess after 20 minutes to 1 hour, the car allows me to do one button push to turn AC Power on only and if I press it again, it turns it off (the way it should) and won't start the engine without me pressing the brake pedal. 3) When I press the brake and push the button to start the car, it will start. Even after driving about 10 miles or so and returning home just now, when I push the start/stop button once, it will shut off the engine, but when I push it a second time, it turns the engine back on without me holding the brake pedal rather than completely shutting down the car. My attempts at a solution: I VO Coded BDC_Body and Cleared All DTCs right after - this was done last night. So, today, those same issues persist. In order for me to shut down the car completely, I have to push button one time and then lock the car. I have checked all the codes that deal with this function and they are in BDC_Body: TCM_StartLock_Brake - default is aktiv - this is so that your car starts only by holding the brake pedal. shawnsheridan and other coders/people that know cars, what should I do? Should I VO CODE EVERYTHING except DME?? My only option at this point seems like a dealer visit (a big hassle for me because I will have to take out my 6WB in order for them to properly use ISTA/P to VO Code everything) and remove my RaceChip (you know how annoying this is on the 50i). PS: I need to do an alignment as well, and I hear a slight knocking sound of the left strut even though I saw him tighten everything. So, I will have to ask BMW to fix that as well. And I thought I was over all my problems... Your advice, tips, and thoughts are most appreciated everyone! Thank you!
2014 X5 50i X-Line // Mineral White
03-01-2015, 03:36 PM | #2 |
Rep 781
OK - relax and take a break. Let the car sit until tomorrow and try again fresh. You might be overlooking something simple. If the MASTER is stumped we are all in trouble!!
03-01-2015, 03:42 PM | #3 | |
Rep 3,990
However, thanks for the reply and sound advice . I really thank this community for its positivity. It's nice having the beast back in my garage.
03-01-2015, 03:46 PM | #4 | |
Rep 535
If the worst comes true, you are so skilled in taking everything on and off anyway, you can easily handle this and just let dealer do the work for you. Keep up the good work bro, we always appreciate what you have done and continued to do! |
03-01-2015, 03:48 PM | #5 |
Rep 1,181
Honestly? With ALL the coding and tweaks you've done, especially wrt just experimenting with various settings, I would indeed start fresh and return all codes back to stock. Then start over. I always like to start from a known baseline after many edits/tweaks.
As for the suspension, I've had clunks after strut/spring swaps and the culprit for me has always been to top hat retention nut. Even though I thought I tightened it down appropriately, after the clunks, I was able to tighten even further, resolving the clunk. Good luck!!!!
A little mod here, a little mod there...
03-01-2015, 03:50 PM | #6 | |
Rep 3,990
03-01-2015, 03:56 PM | #7 | |
Rep 3,990
Here's my next question to all of you. Should I remove my V1 radar detector that is hardwired into my rear view camera (this btw has nothing to do with any errors because it's been installed error-free for half a year). Should I also remove my DASH CAM. This is a BIG concern of mine (would be a pain to remove), and it was 100% properly installed and the button pushes and engine starts all worked correctly with it installed. So, I know 100% this is also not the culprit; I actually even turned it off to test and it has nothing to do with it. Thanks .
03-01-2015, 04:26 PM | #8 |
Well versed in the care and feeding of BMWs
261
Rep 733
If you were in Virginia I'd say take out the V1. But you're not. Leave them both in, unless you have reservations about the security of valuables left in your ride that most dealers will not take responsibility for when they turn up missing.
I remove anything I don't want to replace simply because I was lazy! Like you said, neither has any bearing on your issue. Hope it gets sorted promptly, you've put in too much effort to have anything less than a flawless ride.
B&O, parking assistant, executive package, 3rd row seats and the manual rear shades are the ONLY items we didn't order. Having everything else makes our F15d a NICE ride.
03-01-2015, 04:34 PM | #9 | |
Rep 3,990
03-01-2015, 04:40 PM | #10 |
Rep 1,181
It's not the nut that holds the spring/strut combo in place to the car. It's the top hat nut that holds the spring in place. The force of the spring pushes against this hat. When you go over, say, a speed bump, the spring compresses and if the retaining but isn't tight, there's a tiny bit of free play allowing the hat to move. Once the spring releases after the bump, it'll push the hat back up thereby causing the clunk.
So have your guy tighten that but again on the car. If the noise is still there, I'd have him pull the spring/strut assembly, compress the spring, then fully tighten the nut before decompressing the spring. As for the dash cam, we know the writing on the wall. The dealer will use ANYTHING to claim that it was the fault of something we installed. So, I'd take a couple days and try all the coding reset, etc. first to see if things get resolved. If the dealer is your last resort, I'd unfortunately bite the bullet and remove the dash cam. V1 I'd leave in place as they're more familiar with it and it's only a hardwire pwr install. The dash cam ties into the screen so they can claim you messed with the iDrive system.
03-01-2015, 04:47 PM | #11 | |
Rep 3,990
The nut you mentioned- I believe we are talking about the same thing. It's a nut in the engine bay for each strut for keeping the strut in place with the body of the vehicle. As you said, when I go over bumps, I hear this knocking, so it could be not 100% tight as you mentioned.
03-01-2015, 05:07 PM | #12 |
Rep 1,181
I don't think we are. There are three small nuts at the top of each shock tower in the engine bay. Those nuts hold the spring/strut combo to the car. There's an open circle in the middle and there's a single BIG nut. That nut holds the top hat of the spring. That's the one that needs to be tightened. Took a quick, not so clear pic. The nut I'm talking about is to the left of the little silver nut. It's the black one. (Took this pic with my iPhone so not sure how it'll look after posting; can edit tonight when I'm on the tablet if it's horrible)
The only way to tighten any of the nuts is to pull all the plastic cowling at the bottom of the windshield.
03-01-2015, 05:17 PM | #13 | |
Rep 3,990
I'll take a picture for you when he tightens it up again.
03-01-2015, 05:23 PM | #14 |
Rep 1,886
You are not allowed to ask questions or ask for help here. Do you know how depressing that is for most of us?
03-01-2015, 05:24 PM | #15 |
Rep 3,990
Hahaha, there's no I in team, Niko, and we all are a big TEAM . I learn just as much from all of you - knowledge is endless .
03-01-2015, 05:36 PM | #16 |
Rep 5,066
I can't offer any help since I have no idea about coding and I guess I missed your post about losing your suspension.. what happen to it and where did it go lol?
03-01-2015, 05:40 PM | #18 | |
Rep 3,990
Thank Ashot .
03-01-2015, 05:49 PM | #19 |
Rep 18,721
@opasha, suspension wise, so check the lower bolt that is holding the bottom fork to the shock body. Also make sure that the shock body is properly sitted inside the lower fork. I usually uses a floor jack to push up the suspension up before I tighten the bolt.
While for the coding, after you VO code and FDL everything, let the car sleep and see if that solves it.
03-01-2015, 06:17 PM | #20 |
Rep 18,721
@opasha, here is the picture.
What I meant was bolt #3 in the diagram. Also check the direction of the top mount how it supposed to be. I believe there is a indicating triangle symbol to tell you how the uppermount supposed to be positioned. And the nuts on #10 and #11. I hope that helps.
03-01-2015, 06:18 PM | #21 |
Rep 18,721
Damn mobile app.
03-01-2015, 06:24 PM | #22 |
Rep 450
Regarding issue no 1, I too have coded radio & gps to turn off when you open the drivers door but for this work you have to wait for everything to stop when turning off the car with one button press otherwise opening the door doesn't turn everything off?
I regularly have this not work for me as the time it takes for everything to stop is more than it takes for you to press the button and open the door, you have to consciously add a delay of a few seconds. |
