12-29-2014, 09:13 PM | #1 |
Rep 51
Iphone 6 USB
Is there any way to use the iPhone 6 in non i drive Professional audio. If I select usb it dosen't recognize the phone and I can't play my music and have track information on the radio Lcd. I did search about the Y cable, with this cable will I have information display on the lcd or I need to choose auxilary option instead usb ?
Thank you |
12-30-2014, 01:11 PM | #2 |
Rep 64
Drives: 08 E88 135i
The Y cable will give you track/playlist/etc control.
If you opt for the lightning y cable, get one from bmw, not a random cheap ebay one. It actually has chips in it that convert the lightning signal into a format the car can understand. Likewise, if you go for the 30pin + adapter y cable, get an apple 30 pin to lightning adapter, not a 3rd party one. The adaptor is what takes the digital lightning connection and makes an analog audio signal from it, and apple's are generally pretty good. I personally use the 30pin y cable + adapter setup, only because the lightning y cable is relatively new.
F83
