      12-19-2014, 10:26 AM   #1
dubluv17
Drives: 135i
Rear seats blocking a lot of bass to the cabin
Does anyone else have this problem? I love the way my sub sounds with one of the rear seats laid down, but if they are both up I don't hear that much bass. I'm only at 300 watts RMS to a 10W3, but it's plenty when the seat is down. Is there any way to help the bass get to the cabin. Taking out the rear deck speakers? I'll be running a 2.1 when I eventually get my components in, so I wouldn't need the rear speakers. Just curious to see what other people say about it. Do you really need 500+ watts RMS to hear it in the cabin?
      12-29-2014, 08:18 AM   #2
mechavore884
mechavore884's Avatar
Drives: the fat mobile
what frequency do you have set for the filter? (just from a technical standpoint bass travels relatively far) truth be told though I know W3's arent to strong as is but you may have to change its location for better imaging
      12-31-2014, 09:33 AM   #3
dubluv17
Drives: 135i
Low pass is around 110. The deep notes are very prominent when one of the rear seats is down. In fact, the sub might be a little more than I want in that configuration. The exhaust does drown it out at some times though. But when the seats are up, I only barely hear the kick of the bass. Almost zero of the lower notes get by. It doesn't sound right that you should have to put 500-1000 watts RMS in the trunk just to make it sound like a 300-500 watt RMS sub in a hatchback/open trunk setup. I dunno, maybe I just need to do it.
      12-31-2014, 09:34 AM   #4
dubluv17
Drives: 135i
FWIW, I'm using the TPLSM3 enclosure.
      12-31-2014, 09:55 AM   #5
Solo_M_Tech
Solo_M_Tech's Avatar
Drives: 2014 M5 6MT
2014 BMW M5  [0.00]
Rear seat delete. Problem solved.
2014 M5 6MT
      01-01-2015, 11:19 PM   #6
DietTab
DietTab's Avatar
12
Drives: 08 135i
Put some ports from the trunk to the cabin
LSXOCET - 404rwhp @ 1600 lbs curb weight... bonkers fast
      01-06-2015, 12:16 PM   #7
dubluv17
Drives: 135i
Could you elaborate on this? Can I use the rear speaker cutouts for this(won't be using them)? Will simply removing them solve the problem, or do I need a port placed in each hole like a ported enclosure? I've never had to do this. Thanks.
      01-06-2015, 04:35 PM   #8
DietTab
DietTab's Avatar
12
Drives: 08 135i
Either or.
      01-09-2015, 03:59 PM   #9
mechavore884
is the box ported or sealed...and if its ported what is it tuned to?
      01-23-2015, 05:28 PM   #10
dubluv17
Drives: 135i
It is a sealed enclosure. As I mentioned earlier, it is the TPLSM3 enclosure. Here's the link for more info.
http://www.1addicts.com/forums/showthread.php?t=308823
      01-24-2015, 10:21 AM   #11
mrvco
mrvco's Avatar
Drives: 128i
2008 BMW 128i  [0.00]
Remove the rear seats and install a board with a couple of 15's in it and use the trunk as the enclosure. That was the hot setup way back when I was in high school.
Year One of the One, N.A.
Montego Blue/Coral Red, 6MT Sp/Pr/Wi/Xe
      01-27-2015, 11:05 AM   #12
dubluv17
Drives: 135i
LOL, no thank you. I'm into SQ, not breaking glass...
1addicts
