      12-15-2014, 10:50 AM   #1
Kizzu
Malta
41
Drives: Bmw 125i Black Sapphire
minimum offset required to run 265s
So, I am looking for a set of staggered wheels which will make me able to run 245s front and 265s rears (18"). The car is mildly lowered and not looking to go for the "stanced" or / \ look. Will 9.5 et45 do the job for the rear? If not what is a good offset for such width on the rears?
Thanks
bc br's, afe airscoops, stud conversion kit. injen intake, p-torque tune ~220whp, muffler delete, 335i front brake kit, performance sideskirts, performance trunk lip.
      12-15-2014, 07:10 PM   #2
Eyeman
Eyeman's Avatar
122
Drives: 2008 135 blk, blk, step
Alot of what tire will fit depends on the tire brand, they are not all graded the same. Even with all that, you would not be able to pretty much any 265 rear tire on a et45 wheel without rubbing. Et55 would be a good offset. You still will rub with many 265s.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
      12-15-2014, 07:22 PM   #3
cammula
Drives: 2011 Alpine Whit 135i Coupe
You'll need a very high offset probably 50+ and a very low profile tire nothing over a 35 sidewall
      12-17-2014, 09:52 PM   #4
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
I'm running a 40 offset and a 245/35-18 mpss in front with no issues. I am running -1.5 camber though which helps. No fender roll or pull. I know I could run a 42 offset which would reduce the camber requirement slightly. I know it's only 2 mm but fitment is tight and requires some diligence.
Running a 45 offset with 245/35 in the rear. I suspect a 55 would be required to get the 265s on.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      12-18-2014, 12:30 AM   #5
John_01
John_01's Avatar
Australia
232
Drives: E90 325i, E82 135i
I think you will need ET52 as the absolute minimum to be workable. ET45 is likely to be a big problem IMO. Fitment will be tight with most 255s.
      12-18-2014, 02:55 AM   #6
Kizzu
Malta
41
That's what I thought too and unfortunately there are only two brands with the same spoke style which does them unless it's custom 👎
1addicts
