12-11-2014, 11:09 AM | #1 |
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Best Place to Install Amp in E82 (Avoid Whine/Interference)
It seems the most common place to install an amp is the tray under the trunk, next to the battery? Is this safe from any interference or whine? Are there any other stealth locations one should consider?
I was thinking perhaps left side of trunk in between tail light and wheel arch. I have the Logic-7 system FWIW. |
12-11-2014, 05:03 PM | #2 |
Rep 64
Drives: 08 E88 135i
Hifi OEM location is the left side between the light and arch (at least on my e88, the 82 should be identical).
My XD600/6 is where the OEM lived. Took out the OEM + its mounting HW and velcroed it to the floor underneath. Originally had power running from there to the tray next to the battery via a handy little path built into the plastic liner where the trunk mechanism is. The Ground is an oem ground location on the wheel well underneath the trunk liner IIRC. While the XD600/6 does fit... its snug. Assuming the e82 is identical to the e88... I would not go much larger size wise. |
12-11-2014, 06:49 PM | #3 | |
Rep 12,565
12-11-2014, 07:08 PM | #4 |
Rep 64
Drives: 08 E88 135i
The L7 amp is in a different location than the Hifi OEM, so both fit at the same time. L7 should be near the B pillar drivers side.
Just because I'm curious, how are you planning on getting the new amp's inputs? |
12-11-2014, 07:10 PM | #5 | |
Rep 521
12-11-2014, 07:14 PM | #6 |
Rep 12,565
12-11-2014, 09:18 PM | #7 |
Rep 64
Drives: 08 E88 135i
