10-05-2014, 11:18 AM | #1 |
Rep 8,626
Full Idrive Retrofit
Has anyone done a OEM full navigation retrofit if you have never had idrive? I know it requires a different dash. Does anyone sell a full kit?
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
10-05-2014, 02:02 PM | #2 |
Rep 155
I've done it, look four threads down.
10-05-2014, 03:09 PM | #3 |
European Editor
10589
Rep 22,992
You only need to cut a whole for the Nav screen. The entire retrofit can be done. But its not cheap at around 2K euros parts and labor.
10-05-2014, 04:29 PM | #4 |
Rep 155
The climate controls doesn't fit that good if you don't change the dash, but other than that it's working fine.
I haven't changed mine, but the climate panel thing is quite annoying, so I've sourced a "new" dash from eBay from a car with factory fitted iDrive. |
10-06-2014, 05:46 PM | #5 |
BMW Master Tech
587
Rep 850
Drives: E30, E36, E82, E90, F10, F80
Garage List 2015 Aston Martin V ... [0.00]
2010 Lamborghini LP ... [0.00] 1985 Alpina C2 2.7 [0.00] 2017 BMW M3 [0.00] 2008 BMW 128i [10.00] 2013 BMW 135is [0.00] 1992 BMW 325i [0.00] |
Don't bother going CIC. Do the NBT retrofit. You will love your life a million times more.
135is #502 of 586
BMW LED Performance Wheel | OEM FULL Carbon Fiber | E9X M3 Gauge Cluster | E9X Exterior Mirrors | E9X M3 Full Suspension | E9X M3 Diff | PT-CAN2 Enabled | Bilstiens | Michelin PSS's | NBT Navigation Retrofit with Touch Pad |
