XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      08-07-2014, 08:44 PM   #1
JVX6M
JVX6M's Avatar
Drives: 2023 BMW M3 Comp
I have read many threads of you others having had the reduced power engine malfunction on your M's. Well I was hoping I wouldn't have to experience this but I too did this morning. I started the car no excessive turnover or lag starting. Pulled out of garage and within minutes at the first stop sign my X5M was idling super rough for the first time having it for the last year. Continued to do so till I got to my first destination and shut her down. After a re start immediate rough idle again followed by the CEL and the engine malfunction and reduced power message. I shut it down before pulling off restarted and shut it down again and one more re start and pulled away with no CEL light and back to normal idle. Any others that have experienced this in similar fashion where the light went away as well as the rough idle?
      08-08-2014, 08:54 AM   #2
Jimshorts
Jimshorts's Avatar
19
Drives: x5m
Ive had this frequently which sucks. From what ive read it can be numerous problems.
How many miles do you have on your truck? How much gas was in your tank when your started it?
Ive noticed if i have a low tank this can happen and have heard other that had the same issue. Could be a sign you need new spark plugs and injectors. Also my tech told me moisture could have just gotten in there and it will be fine after running a bit.
2010 BMW X5 M Eurocharged: 12.298 @ 112.860 MPH Tune only.
2005 E55 AMG 11.93 @ 117 1/4 mile 7.75 @ 95 1/8mile tune, shorties, street tires. Sold
      08-08-2014, 11:55 AM   #3
upstate650
upstate650's Avatar
Drives: 2014 650xi Gran Coupe Msport
2020 BMW M340xi  [0.00]
pull the codes and see what they are - the codes don't lie. You can get them read at any autozone if you don't have a reader.
2014 BMW 650xi Gran Coupe Msport Black Sapphire Metallic on full black merino leather. 20" M5 343M wheels for summer, 20" 373 wheels for winter with Nokian Hakkapeliitta 8 studded snow tires. M6 CP exhaust with M6 Diffuser and ///M Performance carbon fiber finisher. Mission Performance stage 1.5 and transmission tune.
      08-08-2014, 12:25 PM   #4
Jimshorts
Jimshorts's Avatar
19
Drives: x5m
Mine tends to kick Cylinder 5 and 8 misfires.
      08-08-2014, 05:17 PM   #5
JVX6M
JVX6M's Avatar
So if the CEL is not on anymore the codes can still be read by autozone?
      08-08-2014, 08:39 PM   #6
MikesX5m
Drives: 2012 BMW X5M
I had similar issue. Bought a code reader and I had some cylinder misfires. Told my SA and I got 8 new injectors! Car now runs perfect.
      08-08-2014, 10:58 PM   #7
Jimshorts
Jimshorts's Avatar
19
Drives: x5m
Maybe I'm due.
      08-09-2014, 02:01 PM   #8
theonesupreme
theonesupreme's Avatar
12
Drives: X5M
it wont go away unless you erase it.
i have the same issue the stealership just reprogram the whole car instead of replacing the fuel injectors.
then the light never pop up again, i wish they replace the new one for me
X5///M WHITE, VELOS STAGE 2, AKRAPOVIC DOWNPIPE + FULL EXHAUST, KW V3 , VORSTEINER FRONT LIP + REAR DIFFUSER.......ETC
      08-09-2014, 08:24 PM   #9
JVX6M
JVX6M's Avatar
So why reprogram the car if bmw is reading the fault code with their high tech stuff wouldn't they just fix the issue or replace the faulty injectors or as a whole?
      08-10-2014, 10:08 PM   #10
upstate650
upstate650's Avatar
Yes, but my SA says some clear automatically after 30 days if they don't recur. Not sure if that's true or not.
      08-12-2014, 10:20 AM   #11
akashyap
Drives: F80 M3 & E46 M3
Codes do not go away automatically. They are there until cleared. The light can go off if it is a small issue and the DME thinks the issue has been rectified.... ex a lose gas cap
You prob need new injectors? Have they ever been replaced before? When was the car manufactured?
E46 M3
CDV Delete, Auto Solutions 30%, SGT Coilovers, TopSpeed Exhaust
F80 M3
Stock
      08-12-2014, 10:55 AM   #12
JVX6M
JVX6M's Avatar
Vehicle production date was 05/11 It's a 2012. Had spark plugs replaced November of last year.
      08-12-2014, 01:15 PM   #13
MonacoJoe
Drives: X5M - Carbon Blk
i am betting its the injectors
pretty much at the three year anniversary (40-50K miles) it happens to almost everyone
you are still on manuf warranty - go get them replaced. it will keep happening
      08-12-2014, 04:59 PM   #14
upstate650
upstate650's Avatar
Somewhere there is a way to induce a cel if it is your injectors. I think by driving in sport mode and downshifting to make it run hard at high rpms. The bad injectors can't feed enough fuel and it will throw the CEL. I would want to take it in with the CEL showing.
      08-12-2014, 11:10 PM   #15
JVX6M
JVX6M's Avatar
Interesting point! Yeah still nothing driving normal mpg still 16.5, drives hard is M mode even when shifting. Don't want to waste my time at dealer because of no CEL. I'll give it another week and see.
      08-13-2014, 07:57 AM   #16
upstate650
upstate650's Avatar
Did you check for codes at autozone?
      08-13-2014, 09:13 AM   #17
JVX6M
JVX6M's Avatar
Auto zone cannot read anything if there is no current CEL on the vehicle. Just left there.
      08-13-2014, 09:19 AM   #18
infamousdiz
infamousdiz's Avatar
Drives: (17 X5M)gone 2018M3CS HERE
my dealership replaced the injectors with out CEL. Rough ideal and long crank.....new injectors and sparks no more issue
      08-13-2014, 04:30 PM   #19
akashyap
What you can do to reliably induce misfire codes is pull the acoustic cover off while the engine is running. And look on both banks for the coils that sit on top of the spark plugs. They are circled in yellow in the pic below. PhotoCred to BES335xi from n54 injector swap diy. You can lift up on the locking tab on the side where you see the wires going into the coil and this will stop the spark plugs from firing in that particular cylinder giving you misfire codes AKA replace injector codes. Do this while the engine is running 1 at a time on as many cylinders as you can. You will have enough codes to get all injectors replaced.
E46 M3
F80 M3
Stock
      12-21-2014, 01:23 PM   #20
theonesupreme
12
Drives: X5M
it is too late that i found this trick to surprise the dealer
the problem came after the warranty was over
so there is no forum member pay on their own, to replacing the fuel injectors?
      12-22-2014, 06:04 PM   #21
sonic03inSC
sonic03inSC's Avatar
Drives: 2011 M3 E93
I just had my 2012 X5 50 in. Took them 10 days to replace 3 injectors, dump all fuel due to to high of ethanol content (15%), and then replace all spark plugs when it still threw codes. This was at 39k miles and the kicker is all injectors we're replaced at 31k miles.
2011 M3 E93 DCT
2012 X5 50
      12-22-2014, 10:33 PM   #22
SoLo
Leader
SoLo's Avatar
Drives: E30/S54turbo,F10535I,E70X5M
Go to a independent German Repair Shop that has a BMW scan Tool(Autologic).if you have not cleared the code with a scanner then it is still in the backround even though your CEL is OFF.if you have done your spark plugs then i would not doubt it if one of your coils might be giving up on you.
xbimmers
