07-30-2014, 01:08 PM | #1 |
Rep 102
Turn signal issue
Hey guys, I have an issue with my right turn signal. When I bought the car it had aftermarket blue bulbs for the front turning signals and the right was not working. So I pulled it out and the bulb was good but the socket was burned out. I bought new from the dealer installed everything works fine but some reason I still get warning on my dash that the light is not working even though it is, sometimes it doesn't happen sometimes it does. Any suggestions how to fix that?
08-01-2014, 11:28 AM | #2 |
Rep 13
Do you have access to an OBD cable? You probably need to reset the error codes in INPA.
If that doesn't work, disable bulb check for turn indicators with NCS Expert (FRM module). |
