07-16-2014, 07:33 PM | #1 |
Rep 939
BMW PERFORMANCE BRAKS on Sale
Hi guys I found this on facebook and thought ill share it with you all.
Brakes Direct 15 July ATTENTION E82/E88/E90/E90/E91/E92 OWNERS! Brakes Direct's 'BIG BRAKE Migration Sale' is on now! Upgrade from 300mm rotors to 338mm ECS 2-piece rotors and 6-piston calipers and Hawk HPS performance brake pads! Requires the use of 17" or larger wheels. This 6-piston big brake kit makes your BMW a super-stopper, with 338mm ECS 2 piece rotors, and six-piston calipers loaded with new pads. Requires 17-inch or larger wheels. Kit includes everything needed for install: • BMW Performance 6-piston calipers • ECS Tuning 2-Piece 338 x 26mm rotors • ECS Tuning Exact-Fit Stainless Steel Brake Lines • Hawk HPS pads • Pad wear sensor • ECS stainless steel rotor set screws Minor modification of dust shields may be required. ONLY $2297 delivered! Sale ends 31st July, with delivery early to mid September! To order or for more information give us a call on 1300 724 943! — at Brakes Direct. https://www.facebook.com/brakesdirec...levant_count=1 |
07-16-2014, 10:33 PM | #4 |
Rep 3,099
07-17-2014, 12:42 AM | #6 |
Rep 939
07-17-2014, 02:00 AM | #7 | |
Rep 9,156
07-17-2014, 06:39 AM | #8 | |
Rep 34
rear's require the specific bmw performance rotors, or you can do a 135i hub flange conversion |
07-17-2014, 05:02 PM | #9 | |
Rep 1,054
http://www.1addicts.com/forums/showthread.php?t=994779
07-17-2014, 05:40 PM | #10 | |
Rep 3,099
i did the rear 135i hubs, other than that, yeah as already said, you could get BMWP rotors and not swap out the hubs, but they're harder to get and a lot more expensive than 135i rotors. |
