07-27-2010, 09:40 AM | #1 |
Rep 342
Drives: 2015 F85 X5M
Macro Lens Nikon 60mm Vs 105mm
As the title shows I am looking for a Macro lens and can't really decide between the two. I was looking to see if anyone here has used either one or both and would have a recommendation.
I already have a 50mm and a 70-200mm but they are not able to get close enough for detail shots at weddings and portraits. Of course it would be fun to play with either one at trying to get some great shots of bugs and other little critters (clearly the 105mm would be better for that). Only real difference I see is length and price. Anyone have any other thoughts on these two lenses? Thanks!
07-28-2010, 02:18 AM | #2 |
Rep 5,493
I have had both - the 60mm macro is beautiful, but the working distances are just way too short. There's no flexibility in the lens, and if you do want to take close ups of critters etc you'll find that you need to get so close you'll scare them away.
The 105mm is a much better working lens and can be used as a decent portrait lens as well. The 60mm is really only for copy-stand work and nothing more.
... ... DMS Remap Review ----- Quaife LSD Review ----- Hartge Antiroll Bars Review ----- Bilstein PSS10 B16 Ride Control Review ----- Detail by ShineOn ----- Paintshield Review |
07-28-2010, 11:07 AM | #3 | |
Bootleggin' 'n Gunrunnin'
143
Rep 2,372
Maybe try some extension tubes on your 70-200? The Kenko ones allow for AF and metering, although you probably want to manually focus if you are at macro distances.
http://www.bhphotovideo.com/c/produc....html#features Another option is a screw in "close up lens", like the Canon 500D. These are 77mm lenses that screws onto the front of your glass (so it isn't Canon specific.) A few other manufacturers make them as well, such as B+W, Heliopan, etc. http://www.bhphotovideo.com/c/search...947+4294955264 I personally have no experience with extension tubes nor the close up lenses. Here is what "mb" posted on Nikonrumors regarding the two: Quote:
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles 2019 Ford F450 STX, Oxford White 2013 Ducati Multistrada Touring S, Red |
07-29-2010, 03:26 AM | #4 |
Rep 7,308
Drives: see above.
I've been pricing up these tubes for a while - has anyone on here 1st hand experience of them?
I love macro and need a better way than using the Canon Sx1 with a raynox on it.
07-29-2010, 04:33 AM | #5 |
Rep 5,493
The tubes won't work well on the 18-200mm lens you have. You're better off with a Canon 500D filter and doing your macro shots at around 180mm on the lens. As long as you use a decent tripod and stop the lens down to around f/6.3 you'll get amazing results. Because you're using a 180mm focal length, you'll still get decent enough background isolation with the close focussing
07-29-2010, 03:12 PM | #6 |
Rep 7,308
Drives: see above.
At £179.99 for the 77mm version, I may be better looking out for a second hand 100mm micro?
07-29-2010, 10:49 PM | #7 |
Rep 189
I've got fantastic shots of insects with my 60 and while yes, the working distances are short it's far from useless. The 105 is much better for that but you probably want a 200 if that's really you're thing so even then it's a trade off. And if you're shooting inanimate objects I think the 60 is a better choice then the 105. Plus it's cheaper, especially if you've got a D80 or any other Nikon that can use the older D lenses. A used one from Keh.com is ridiculously cheap compared to what I paid 3 years ago new.
