11-16-2009, 03:13 PM | #68 |
Rep 658
11-16-2009, 07:37 PM | #69 | |
Rep 304
Congratulations.
11-16-2009, 08:22 PM | #70 | ||
Rep 1,247
Drives: E60 M5, E71 X6M, E46 M3
Garage List 2006 BMW E46 M3 'vert [0.00]
2008 BMW M5 [0.00] 2011 BMW E92 [0.00] 2012 BMW X6M [0.00] 2003 E46 M3 [0.00] |
For starters... "Acute renal failure" (ARF) has traditionally been defined as the abrupt loss of kidney function that results in the retention of urea and other nitrogenous waste products and in the dysregulation of extracellular volume and electrolytes. The loss of kidney function is most easily detected by measurement of the serum creatinine which is used to estimate the glomerular filtration rate (GFR). The proteinuria to which I was referring is an isolated heavy proteinuria not to be confused with the nephrotic syndrome and is suggestive of a glomerulopathy (with the same etiologies as the nephrotic syndrome), but is not necessarily associated with the multiple clinical and management problems characteristic of the nephrotic syndrome. So...clearly you do not understand ARF and its difference from the causes of proteinuria...back to Renal Physiology for you The supplements cause the glomeruli to become "leaky" and allow the large chain globins (albumin) to spill and also allow the masking substance that is contained in the supplements to spill into the urine and interfere with screening tests that are commonly based on immunoassay techniques, which allow for rapid and inexpensive testing. Validity and reliability of urine drug test results may be compromised by tampering with the sample. Substitution with another sample can be reduced by directly observing sample collection and following procedures for chain of custody. Samples may be adulterated by dilution or other available additives (many of which can be bought over the Internet) to interfere with the screening assay. In addition, ingesting large quantities of liquids, taking diuretics or adding water or household bleach to a urine sample may mask illicit drug use. Your move
Current: 2006 E46 M3 'vert 6-sp 2008 E60 M5, 2011 E92 328 6-sp, 2011 E70 N55, 2012 E71 X6M
11-16-2009, 09:19 PM | #73 |
Alpine Master
111
Rep 1,310
No, he's renting a 740 square foot finished basement for $500/month. I'm renting the main floor and the upstairs, about 1320 square foot, for nearly double that. We are not. You are wrong.
Alpine White with Taupe Leather 135i, Sports Package, Heated Seats, Comfort Access, iPod Adapter
Fastness: http://www.1addicts.com/forums/showthread.php?t=252727 |
