07-31-2023, 08:02 PM | #1 |
Rep 3
Cleaning Live Cockpit Pro screen
guys looks like a got a somewhat permanent smudge/stain on my dash screen on my '21 X5. Anyone have any luck cleaning this off?
pic attached |
08-01-2023, 09:39 AM | #3 |
Rep 1,261
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
I usually start with a lens alcohol wipe to get the crud off then hit it with a LITTLE glass cleaner on a microfiber and wipe dry.
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
08-02-2023, 05:32 PM | #5 |
Rep 88
I'd recommend a small amount of glass cleaner on a towel to make it slightly damp and then go back over it with a clean glass microfibre dampened with a bit of water. The water gets rid of any residues left behind by the glass cleaner and the glass cleaner will tackle the oils from the fingerprint type mark.
08-03-2023, 12:58 PM | #6 |
Rep 968
A light mist of water (be sparing) has worked best for me on the X5, and if it doesn't fully remove it on the first pass, just repeat the process. It's the only way to clean without leaving residue or streaks.
2024 M3 CompX Dravit Grey - MP HAS - Millway - MHC+ carbon - CS software - Fabspeed - MAD - PPF
2019 G05 X5 x40i, built 2001 600whp B5 S4. |
08-10-2023, 06:05 AM | #7 |
Rep 12
I typically use Maguiars Intetrior Detail Spray on screens and instrument clusters (shake well, spray a small amount on a microfiber towel, wipe gently, then use a dry portion of the towel to wipe off any excess). Works great.
https://www.meguiars.com/automotive/...16-16-oz-spray |
08-22-2023, 09:12 PM | #9 |
@stormtrooper.g83
67
Rep 134
Drives: M4 G83, X6 G06 30d, G22 420i
This is what scared me on my 6MT. After taking delivery, I installed a tempered glass screen protector on both the iDrive and gauge cluster. I can be as rough as I want now when wiping it down. I recommend you do the same once you clean it up!
~ Alpinweiß G83
~ Mineral White X6 G06 30d M Sport ~ Sapphire Black 420i G22 M Sport Sold: 6MT M4 G82 |
08-22-2023, 10:30 PM | #10 |
Rep 621
Start with a tag less microfiber and a spritz of water first and lightly rub.
If that doesn’t work, try a rinseless car wash diluted to the rinseless concentration next. Step up to the waterless concentration next (if you need it). One of those three should work and not damage the screen. I wouldn’t use glass cleaners as many have alcohol and it can dry out the plastic screen. |
