M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      04-04-2023, 07:08 AM   #67
^ Good vid
      04-16-2023, 10:41 AM   #68
lucid21
Drives: 2014 6MT M5 Comp
Originally Posted by autoxautox View Post
That’s the thing, it does have a tensioner, it is the main pulley. It has a u shaped middle so that when the arrow is facing the ac it lets the tension off and the belt comes right off. Then as you turn the crank back so the arrow faces away it tensions it back up, then you put the four bolts back on. It’s a pretty smart design.
I found pics at the very end of this video:
https://m.youtube.com/watch?v=mNb6xTwKYHw
OK, but I don't think this is necessary and seems like a lot of work in a tight space to pull off. My understanding is that these belts will "stretch" to some degree without being damaged and a tool like this will do that for you without the need to "relieve" the tension on the belt. https://www.amazon.com/dp/B00AC60VEC...roduct_details
I've seen several videos of that being done on S63 engines, but I haven't done it myself.
88 S14 M3 (NASA GTS3 racecar) / 11 6MT 550i M Sport / 14 6MT M5 Competition / 15 X5 50i M Sport (tow vehicle)
      04-16-2023, 08:29 PM   #69
autoxautox
Drives: BMW M5 F10 2015 Comp
Cool tool. Thanks for the info, never heard of it.
      04-16-2023, 09:12 PM   #70
lucid21
I'll keep you posted on if/how that tool works. Also, did you need access from the bottom, or could you take care of it from above? Trying to figure out if I should have the car on a ramp before I start. Thanks.
      04-17-2023, 06:08 AM   #71
autoxautox
For the ac belt, I needed access from the bottom. You could probably get away with doing the main belt from the top but it helped to have the bottom access for it as well.
      04-18-2023, 05:53 PM   #72
lucid21
Got it. Thanks.
      04-05-2024, 12:59 AM   #73
kevlarblue
Drives: 2009 335i, 2013 M5, 2006 650i
I just got a 2013 with 65K and it whines just like videos in this thread. Did anybody get results from the tensioner or anything else?
Mine is a 6MT and only makes the noise when in gear and under acceleration and it sounds like it comes from the transmission or driveshaft area. This is not consistent with a tensioner in my opinion because the whine is not present in neutral at any RPM.
      04-30-2024, 11:21 PM   #74
dadcrisis
dadcrisis's Avatar
Drives: 2013 M5
I’m having same issues as you kevlarblue also a 6MT. Have you made any progress in identifying the whine?
I gave DP and AFE intakes too, but I don’t think they’re related.
      05-10-2024, 03:09 PM   #75
kevlarblue
I decided to try a flush of the transmission fluid and that made no difference. It still whines just like before.
Foolishly, I took it to the dealership for the flush and thought they might have an answer or be able to diagnose the noise. They were reluctant to even do the flush because it's a "lifetime fluid" and they don't recommend it (even though the technician does it for his personal M4). Their next course of action would have been to remove and inspect, but ultimately replace, the transmission at a mere cost of $19,600.
The technician suspected the noise is coming from a bearing on the input shaft. I disagree with that because it sounds nothing like any bearing I have ever heard (whining like gears vs a growl or grind like a bearing) but I am not a trained mechanic.
For now, I am going to just live with the noise and continue to drive and enjoy the car. Hopefully a resolution or some information will present itself.
m5post
