02-12-2013, 12:13 PM | #23 | |
Rep 363
I also am one of those car nuts having the autobahn right around the corner. Ive never heard about this hood issue and now im kinda worried about high speeds. My 1M has a tune and i reach speeds higher than 280kmh... is there a fix for this or could you maybe confirm with your friends friend who works at M GmbH whether this is just another story or really has something to it...? thx
frozen grey 1M euro spec for sale: http://www.1addicts.com/forums/showthread.php?t=1093569
02-12-2013, 12:55 PM | #24 | |
European Editor
10642
Rep 22,992
IF it really bothers you you could always retrofit hood pins or those flush hood latches like seen on the Safety 1M car. I have done numerous runs over 280 kph and no problems to date. It really doesn't bother me too much now. I don't think there are many 1er's going over 290 kph. And the car is so bouncy at those speeds... the last thing I am looking at is the hood flopping around. Maybe when the weather gets nicer I'll make a video of the hood peeling up at the edges. BMW addressed this issue on the F2x/F3x's bc you have to pull the hood cable TWICE in order to open it... and then there is still the hood latch safety there. Dack
02-13-2013, 02:57 PM | #25 |
Rep 363
well you're right about paying attention to the hood at those speeds, but the vid idea sounds great... would love to see it once its done...
02-14-2013, 04:18 AM | #26 |
Rep 161
No problem at 250 km/h (on local tracks).
Left to see if it's a problem at 300 km/h (Autobahn), which should be possible in theory since the speed limiter was moved from 250 km/h to 300 km/h.
02-14-2013, 06:34 AM | #27 |
Rep 13,167
Don't exaggerate. You know too that, at those speeds, there is much more at stake than only the physical integrity of the car. No prizes to be won.
///M is art ↔ Artemis
02-14-2013, 08:10 AM | #28 |
Rep 161
...as stated: in theory.
Did you miss this part?
02-14-2013, 09:42 AM | #29 |
Rep 13,167
This picture was released today by the Belgian Road Safety Institute which currently promotes the "Go For Zero" road safety campaign (slogan: "850 killed every year. And you ? Not concerned ?"). This accident happened last Sunday (Feb 10, 2013) on a Belgian highway. 60 year old driver and passenger incurred small injuries. No Photoshop. Pure coincidence. Talking about a copycat...
02-15-2013, 09:14 AM | #30 |
Rep 365
I've read a few of the posts about the stock charge pipe having problems but it isn't clear to me that the folks who have experienced these issues were running a tune or not. It would be good to get some clarification on that issue because it could be that there is no problem when the boost levels are not increased above stock levels. For what it's worth, last summer, when I was at the 2 day M school at the PDC, I asked one of the instructors if the PDC had had any problems with the stock charge pipes on its cars and she said they had not.
02-16-2013, 10:14 AM | #31 | |
Rep 1,479
Drives: 2017 F80 M3
_______________________
1991 E30 M3/Brilliantrot 2017 F80 M3/AW |
02-16-2013, 10:18 AM | #32 |
Rep 1,479
Drives: 2017 F80 M3
Starting issues
During the past 3 weeks I've experienced an abnormally longer crank time before the engine fired up. Usually it starts immediately, but I've encountered 5 times where it has taken 3-5 seconds. Has anyone else encountered this and could this be an early sign of a HPFP issue?
02-16-2013, 01:56 PM | #34 |
Rep 1,479
Drives: 2017 F80 M3
My p3 gauge is showing a cylinder 3 misfire fault code, but the engine isn't misfiring. Very odd. I'm going to clear the code and see if it reappears.
02-17-2013, 04:32 PM | #35 |
Rep 13,167
A Belgian 1M owner informed me earlier this week about a series of recurring random errors/glitches which befell his VO 1M.
According to what he described electronics of his 1M went nuts, as if his 1M was bewitched. His 1M randomly reported all sorts of ill-founded messages on the instrument panel (battery issue warning, seat belt issue warning, airbag issue warning, engine issue warning) but he also witnessed other crazy situations (SAT-NAV cutting out randomly, RPM and speedometer going berserk for no apparent reason [dropping from the actual speed indication to zero indication and back], start/stop button blinking despite the engine being switched off, iDrive button blinking despite the engine being switched off, blinkers not working anymore, windows not fully closing, headlights staying on despite switching off the engine, Park Distance Control no longer operational, etc.). But his 1M did not detonate... Incidents were usually resolved by resetting the engine (switch off and restart). But issues recurred during subsequent drives. Quite some erratic incidents happened randomly when idling before traffic-lights during a drive ("Usually the instrument panel lit up like a Christmas tree and SAT-NAV reported all sorts of weird instructions and warnings"). Most absurd incident was a SAT-NAV message ordering him to switch off the engine, remove the key, unbuckle and open and close the driver's door. So he did and no such message re-appeared. Sounded like a 1M with a "Christine" movie attitude or an ECU on crack, driving the 1M electronics nuts. Owner is a reliable guy and took it to his BMW dealership. If BMW gets to read this someday: the owner documented the 1M lunatics with pictures as proof "or the BMW dealership would have never believed me". BMW dealership scratched its head ("never seen or heard this before"). 1M got checked. Dealership concluded that the antics were caused by ..."a Park Distance Control issue, probably related to humidity". Owner will test his 1M within the forthcoming days and weeks if weird stuff happens again. Must be the craziest 1M story so far. Unfortunately 100% true.
02-17-2013, 04:40 PM | #36 |
Rep 1,479
Drives: 2017 F80 M3
I cleared the misfire code and it hasn't reappeared yet. My guess is that the codes are being thrown when I encounter my starting issue. I'm going to call my SA tomorrow to ask if I should bring the 1M in for a checkup.
02-17-2013, 04:41 PM | #37 | |
Rep 3,070
On a serious note, if ECU gets cooked for any reason anything can happen.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
02-17-2013, 04:47 PM | #38 |
Rep 3,070
Your starting issue is very worrying indeed. Does your car have comfort access? Sometimes it can cause starting issues as well, like late start or even total failure, depending on where you are located at that moment. Let's hope it is something like that.
02-17-2013, 05:03 PM | #39 |
Rep 13,167
+ he must be a real pro on using Photoshop for his pictures documenting several issues.
02-17-2013, 05:19 PM | #40 |
Rep 13,167
About the 1M whose electronics went apparently nuts, see also these similar 1er experiences:
http://www.1addicts.com/forums/showthread.php?t=516220 (speedometer going jojo) http://www.bmw-drivers.de/forum-68/e...n-t-43668.html (electronic failure) http://www.1addicts.com/forums/showthread.php?t=754683 (PDC and humidity) Other examples of 1ers infested by electr(on)ic "gremlins": http://www.1addicts.com/forums/showthread.php?t=442429 http://www.1addicts.com/forums/showthread.php?t=773202 http://www.1addicts.com/forums/showthread.php?t=594848 http://www.1addicts.com/forums/showthread.php?t=396878 I'll create a separate thread re this issue.
02-18-2013, 06:52 AM | #41 | |
Rep 3,070
03-02-2013, 11:53 PM | #42 |
Rep 3,070
How about adding infamous oil control issue? We have been reminded about this nasty problem again thanks to new thread and photos by m3dragon.
03-03-2013, 10:52 AM | #43 | |
Rep 13,167
06-08-2013, 06:48 PM | #44 |
Rep 3,070
Knock Sensor Issue
Artemis, I think we may add the "knock sensor issue" in this Sticky. Here is the ongoing thread that talks most about it:
http://www.1addicts.com/forums/showthread.php?t=839266
