      02-15-2021, 06:47 PM   #1
Haricot_E60
Drives: 2010 535I
Loss of power after new battery (2010 535i LCI)
Hi all, I recently had my battery replaced with OEM spec and registered to the vehicle. After driving it it feels like I don't have full power under ~5k RPM. Once I'm past that the car feels like it should. Prior to the replacement car for throwing over/under voltage codes for the EKPS. Replaced the battery on their recommendation. I asked the tech about it he said the car takes a hundred miles or so to "relearn". Anyone here have any experience with this or have any input?
Thanks in advance!
      02-27-2021, 01:34 PM   #2
Enoe Ulbeht
Drives: 128i Convertible
I also get some overvoltage codes on e61 and my battery is on the way out. interested to see what happened after all in your case. do you still have the issue or did it fix itself?
      10-23-2021, 10:59 PM   #3
mweine
Work Hard! Play Harder!!
mweine's Avatar
Drives: BMW 1M, BMW M3 CS
1989 BMW M3  [0.00]
Thanks in advance!
I never had that issue when I coded in a new battery. I should get an OBD2 reader and check the error codes.
Tags
535i, e60, n54
