06-04-2014, 09:30 AM | #1 |
Rep 584
Top Speed limiter
Is this a coding option on M235i? I know the car order with Summer Tire has Top Speed Limiter removed. Not sure if this can be coded
130mph vs 150mph
CurrentNone! RETIRED [15' GLA250][14' M235i F22 AW-ED 06/16/14][12' 335i F30 AW-ED 05/01/11 PCD 07/01/11] [11' M3 E93 MW-ED 08/13/09 PCD 10/14/09] [09' 135i E82 AW] [07' 335i E90 SB]
[ED Photo 12'] [ED Photo 11'] [ED Photo 09'] [PCD Photo 09'] |
06-04-2014, 11:56 AM | #2 |
Rep 349
First off, the top speed limiter isn't removed with summer tires, it's just increased.
As for the coding, it probably can be done... but some people don't realize the reason the top limit is placed is because the tires the vehicle is sold with don't support speeds higher than the limit, that's why it's put there. Given that, if you know your current tires can support it, give it a shot. The names aren't all that cryptic, so if it exists, it probably wouldn't be hard to find. |
06-27-2014, 01:36 PM | #3 |
Rep 5,262
You should be able to change your VO
Remove S118A "TOP SPEED REDUCTION" Add S840A "HIGH SPEED SYNCHRONIZATION" and VO code FEM_BODY i guess just make sure you test in a "safe" environment |
06-28-2014, 07:07 AM | #4 |
Rep 185
I have no direct personal experience, but it seems (based on postings in other forums) that the top speed limit can only be changed when the car is new for a short period of time. It would be good to know if that information is wrong, so I invite anyone with personal experience to contradict me.
06-28-2014, 11:24 AM | #5 |
Rep 5,262
People usually confuse Remove speed limiter with Increased speed limiter
If you don't have the right tires you get S118A (top speed reduction) 130mph If you have summer tires you get S80A (increased top limiter) 150mph and as far as i know you can always remove that from the VO at anytime Now removing the speed limiter (no speed limit at all) cannot be coded cause it's actually hardcoded in the ESC.... for that you need a tune or a flash to override it |
01-28-2016, 04:15 PM | #6 | |
Rep 688
Drives: 22 TR X3MC
Does it work?
2022 X3M Comp
2013 335i xDrive (Sold) |
01-28-2016, 05:01 PM | #7 |
Rep 5,262
Supposedly yes... but you need to do it before the 10 operating hours of the car...
Then it gets locked and you can only doing by flashing the DME ECU Also the ecu that needs to be coded is the DME and not FEM_BODY and because you can't code the DME with the engine running, you might need to connect a charger to prevent screwing the data file if voltage drops You can also try to change the VMAX directly instead of VO coding but again before the first 10 operating hours of the car |
01-28-2016, 05:22 PM | #8 | |
Rep 688
Drives: 22 TR X3MC
2022 X3M Comp
02-03-2016, 07:38 AM | #9 |
Rep 1,184
Anyone know what top speed would be? The gpower tune claims it would bump the limiter to 186. Could an FBO m235i even hit that if not limited?
I wonder what the tranny winds out at? |
02-19-2016, 10:16 AM | #11 | |
Rep 5,262
to know real speed you should use gps |
02-19-2016, 10:21 AM | #12 |
Rep 32
It was a good amount over 160 line ( probably around 163 or 164mph) is it possible to be 8 or 9 mph over? The gps speed use was only about 1-2mph less. It definitely took me by surprise.
02-19-2016, 08:38 PM | #13 |
Rep 554
My top speed limiter is in my passenger seat. My wife. SLOW DOWN! SLOW DOWN!
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
03-04-2016, 05:02 AM | #15 |
Rep 28
Before I got my car tuned, my GPS top speed was 162 mph. After I got my flash tune with Enzo, I have gotten it to 173 on the drive back from the Nürburgring.
03-04-2016, 08:32 AM | #16 |
Rep 5,577
03-04-2016, 08:52 AM | #17 |
Rep 1,931
Cobb AP in the n54 335 set speed limiter to 198, never got near that...
It's very easy to reach the 130 mph... as others pointed out, you have 10 hours to change it before its locked out. But the 10 hours may already be up by the time it reaches you, driving it onto the ship, off the ship to trailer, dealership etc... Good luck, you can always flash the DME like pointed out with a ENZO or other tune if you really want to increase...
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
03-04-2016, 11:10 AM | #18 | |
Rep 28
As for the RPM, I am not sure, I was too focused on not crashing. My brother was actually calling the speed out for me. I know it had a little more before redline, I just ran out of empty road and was coming up on some cars so I let off. |
