12.1 sec 115.2 mph quarter mile
05-10-2014, 09:12 PM | #1 |
Rep 2,410
This is with Ecotune's remap and downpipe and some of my custom stuff. Stock turbo's/intercooler.
A bit over a week ago this car dyno'd, with NO FANS blowing on it, peak 370 horsepower to the wheels and 538 lb-ft torque to wheels. On a stingy SuperFlow dyno with the biggest rollers they make so dually pickups can be strapped down and tested. Choose your drivetrain loss numbers to get back to engine/crank numbers, but using ~15% drivetrain loss would make things north of 435 hp at the crank... http://www.e90post.com/forums/showpo...&postcount=874 I don't particularly trust dyno's as they can be manipulated easily, and often over predict real world capability, and different dyno's will read different numbers for the same car. So I took the car back to God's Dyno ... the 1/4 mile. Weather around here is hard to predict and schedule around. There was no chance of rain as of 6am this morning. But things didn't work out that way. Weather history at the track location: http://www.wunderground.com/history/...yHistory.html? Plugging those numbers in a DA calculator gives a Density Altitude of ~2100 ft. Very sub-par for good numbers... First rain was ~30 mins before the racing was supposed to start. It takes them ~1 hr to re-prep the track after the rain ends. First passes started at 12:25. Was able to get 3 passes in before the next rain started. Had obligations late this afternoon so I headed out after the 3rd pull. First pull I tried Hotrod's suggestion of 1st gear launch. It was a clown show even with the Hoosier DOT drag radials. Besides not having enough traction in 1st gear at the launch and spinning, the 2nd gear transition spun and kinda got the car a little off center for a moment ... Second pull I went back to 2nd gear launch and used the water box. Even with a good burnout I spun the tires a lot on the launch. Too much boost/fueling at the start... But this run had the best trap speed of 115.9 mph! Third pull was just ~30 seconds before the rain started again. Lowered the rear tire pressure to ~24 psi. Skipped the water box, did a quick burnout, and launched with less boost and didn't use full fueling until the car got going. Was just getting the hang of how to launch this thing... Used the Torque App "Track Recorder" and have video as well overlaid with EGT's, boost, rpm and speed. Going to see if I can upload that to youtube if I have time today. Otherwise tomorrow. Getting into the 11's is only a matter of having non sub-optimum conditions and getting a descent launch... Took video using the Android Torque app's Track Recorder. Had it record EGT's, boost (it has to calculate it from other things...not direct measurement), and speed (the drag tires are a little bigger diameter than stock so the speed is off a tad). Unfortunately, I can't figure out how to get the data displayed in the run from the raw video file. So I had to take a video of the playback of the Torque App Track Recorder to get the data to show up. I thought the EGT data was interesting considering how much power is being put to the wheels. Got the raw video uploaded, but the data is not visible on this one. But the resolution is a lot better. You can also see the rain starting to hit the windshield right at the end. Last edited by TDIwyse; 05-11-2014 at 04:31 PM.. Reason: Updated with link to raw video |
05-10-2014, 10:20 PM | #3 |
Warrant Officer
375
Rep 1,341
Pretty good numbers and power considering the limited availability of tunes we have.
Correct me if I am wrong though, but on a turbo car with electronic boost management, shouldn't DA have no effect? Intercooler efficiency might be slightly effected though.
Deleted, ATM I/C and tuned by B.R.R.
05-10-2014, 10:51 PM | #4 |
813
Rep 3,977
Congrats! The things definitely have 11's in them. I only took mine to the track the first and the last time the weekend before I got rid of the car.. But 11's are just a matter of dialing in everything. Are you still running the kittycatconv?
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) |
05-11-2014, 12:45 AM | #5 |
BMW Advanced Diesel, 2011 BMW 335d M sport...
87
Rep 783
Are you in the USA or Europe, if in USA why not use Malone tuning or Rocketchip... what is Ecotune, are they from Scottland...
BMW Advanced Diesel, 2011 335d M sport...
05-11-2014, 12:49 AM | #6 |
Rep 1,592
Drives: 2011 335d, M-Sport
Love seeing this!
05-11-2014, 05:31 AM | #7 | |
Rep 2,410
There are some things missing from the car at this time right after the turbo. The Ecotune downpipe really helped with EGT reduction. |
05-11-2014, 05:34 AM | #8 |
Rep 2,410
05-11-2014, 05:37 AM | #9 |
Rep 2,410
USA. Ecotune is from Scottland. I'm familiar with Malone and Rocketchip from my VW TDI days, but not familiar with their 335d offerings.
05-11-2014, 05:45 AM | #10 |
Rep 2,410
My understanding (will have to look for references though) is that turbo engines are still impacted by DA, though not as much as natural aspirated ones. The turbo has to work harder to make the same peak boost numbers, which means it could (engine/design dependent) be going outside its efficiency range.
05-11-2014, 06:29 AM | #11 | |
Rep 2,410
http://yakimawpa.files.wordpress.com...ce-handout.pdf https://www.mountaincanyonflying.com/DA%20Workbook.pdf These are generalized and may not apply to our engines, but they show for every 1000' change natural aspirated engines loosing ~3% power and turbo engines loosing ~2.3%. |
05-11-2014, 07:56 AM | #12 |
87
Rep 783
Just curious how you choose your tune company, I'm ready to get tuned just see so many different options without any real world opinions from people who have actually done it, for example Malone and Rocketchip for TDI is basically the same tune, Unitronic for the TDI was crap...all cost the same price and claim the same numbers...
05-11-2014, 10:54 AM | #13 | |
Rep 2,410
Actually, it was largely because Stan at Ecotune was willing to go forward on the remap and downpipe and other aspects that the previous company I used (Evolve) was not. And he had a lot of good feedback from the European 335d owners. |
05-11-2014, 11:10 AM | #14 | |
87
Rep 783
05-12-2014, 03:03 AM | #15 |
Rep 62
Drives: 2014 i3 BEV Giga
TDIwyse is my hero.
2014 i3 BEV Giga
2011 E90 M57y, ZPP, 248, 494, 655, 6FL SOLD and will be missed |
05-12-2014, 11:45 AM | #16 |
Rep 1,766
JBD @ 100% | KW ST Coilovers | M3 rep. front bumper | 888Concepts AE Upgrade | GP Thunder 7500k fogs | Cyba 4" carbon tips | BSW Stage 1 | APEX ARC-8 W/ Michelin PSS | Ziza LED interior | Weisslicht LED side lenses | Sprint Booster | Euro side mirrors | M-Sport semi-conversion | Coded | LOTS of carbon fiber
05-12-2014, 01:24 PM | #18 |
Rep 2,410
Controlling the launch is the main problem now. AWD would really help a lot. Wish I would've been able to do 1 or 2 more pulls...
Maybe I need to have more than ~1/8 tank of fuel to add some more weight on the back end? |
05-12-2014, 01:47 PM | #19 | |
Rep 429
05-12-2014, 01:51 PM | #20 |
Rep 2,615
05-12-2014, 06:45 PM | #21 |
Rep 2,210
how much info do you have on those drag radials? 24 PSI seems like a lot, I used to run 15 PSI in my drag radials (different car) but the 18-20 psi range seems to be a sweet spot for those Hoosiers. FWIW, I had slightly better 60' times on stock runflats with much less power, so the time is definitely there to be picked up if you put in some time practicing the launch. Do you think you are getting enough heat into the tire? I bet with the right combination of pressure and heat you would be surprised by how much you can get out of those tires, they are sticky enough to put 3300 lb Mustangs into the 1.2-1.5 60' club so you can definitely get into the 1.8s with some work, maybe even better. A couple PSI can make a huge difference in those.
With that said, this is pretty awesome. Wouldnt mind going 12.1 in mine... |
05-12-2014, 08:48 PM | #22 | |
Rep 2,410
Well ... I'm a novice at this. I've done less than 10 pulls at the track. Think your suggestion for lower pressure is good. I'll be going to lower psi from the start the next time I try. I drove to the track with the tires on and they were at 40 psi for the drive. Lowered them to ~30 psi for the first 2 launches before lowering psi even further for that last run. I don't like practicing this kind of start as it seems really hard on the vehicle's drivetrain... It seemed to grip much better on the last run. This could be due to the lower psi or doing a dry burnout pre-launch as opposed to going thru the water box and doing a burnout like I did on the first two. Not sure what your experience is on this? Water box or no water box? Might start out at ~20 psi next time. Hopefully I can align schedule/wxr/track openings again sometime soon. |
