BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
Mporium BMW
      11-28-2007, 09:24 AM   #1
gadget
gadget's Avatar
Drives: 09 e92///M SSII DCT
Carbon Fiber Hood
How likely is it that a Carbon Fiber Hood that matched the roof will become available as an after market option. if it were would you get it?
I think it would look OK but would need to see it in person to make up my mind.
      11-28-2007, 05:02 PM   #2
UltimateBMW
UltimateBMW's Avatar
399
Drives: MP4
How probable? I would say it is a definate. When it will come out I can't tell you. But there are CF hoods available for the e46 M3.
Would I personally buy one? Probably not because of the pure expense of the thing. $3000+ for a carbon fiber hood isn't really worth that much to me when the current hood on the car isn't necessarily bland. I can easily see a CF hood on the M3 looking bad ass though.
      11-28-2007, 05:36 PM   #3
Epacy
Reincarnated
Epacy's Avatar
245
Drives: 02 Maxima SE
2008 M3  [0.00]
Yeah, but how much weight are we talking about saving? The exisitng hood is already made of aluminum.
      11-28-2007, 07:26 PM   #4
UltimateBMW
399
Drives: MP4
How much would you guess the paint weighs?
      11-29-2007, 08:44 AM   #5
gadget
gadget's Avatar
Although CF hoods are normally offer weight savings I agree that the difference with aluminum may not warrant the expenses as any weight savings would be minimal.
I am more interested in the CF hood from an aesthetic point of view and whether or not it would complement the roof.
I am most interested in seeing this with either AW or SSII
      11-29-2007, 08:00 PM   #6
OC ///M
Dr. Octagon
OC ///M's Avatar
Drives: Moonstone e92 M3
With arrivals stateside expected in March, I can tell you that companies like Vorsteiner will have them available around the same time if not sooner...
OC ///M
2013 E92 M3 Individual
Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB
      11-30-2007, 12:58 AM   #7
Big Windy
Big Windy's Avatar
Drives: None
negligible i'd think. maybe 2-4 pounds max with all the coats. but thats a total guess.
i don't think i'd go for it. i like the stock hood and i think it might look retarded/ricer with a CF hood. car would have to be SSII or AW to pull it off though.
      11-30-2007, 02:41 AM   #8
swamp2
swamp2's Avatar
Drives: E92 M3
The CF roof saved a whopping 11 lbs compared to painted steel (compared to a steel roof without sunroof). It would probably be something like 30 lb in steel, 20 lb in CF (very rough but reasonable estimate). The hood is larger and has more reinforcing sheets but could use a thinner material since it is a non structural/safety component. I'd guess in steel a hood might end up also around 30 lbs. Switching to aluminum could save quite a bit, maybe getting that down to 20 lb and about the same 10 or so lb in CF. So you would save about the same 10 lb going from aluminum to CF for the hood.
HOWEVER... Please (OP) do not do this hideous mod to your beautiful M3 JMHO...
      11-30-2007, 10:51 AM   #9
UltimateBMW
399
Drives: MP4
If it's only a 10lb saving in weight, then the 2-3 lbs. from paint isn't negligible.
Plus, this mod would mess up the 50/50 weight distribution! You'd have to buy the CF bootlid as well just to keep things proper. So this mod is definitely not worth it.
      11-30-2007, 12:30 PM   #10
swamp2
swamp2's Avatar
Drives: E92 M3
...Except that 10 lb is one half of one percent of a difference in weight balance!
      11-30-2007, 06:33 PM   #11
UltimateBMW
399
Drives: MP4
That would make it 49.5/50.5. Which is not 50/50... :sad0147:
      11-30-2007, 09:48 PM   #12
gadget
gadget's Avatar
Isn't the 50/50 without the driver. Unless you weigh nothing you are going to mess up the weight just by sitting in the car. Since you (or at least a part of you will be in the front 50 of the car, the CF hood would actually help offset your weight and improve balance.
Bottom Line 10lbs more or less won't make a difference at all.
      11-30-2007, 10:05 PM   #13
nusevad
O! So Sour!!
nusevad's Avatar
Drives: Fast 240z / Slow M3
1971 Datsun 240z  [0.00]
2008 M3  [9.60]
I bet Vorsteiner will come up with a sick CF hood with more functional vents for the new M.
      12-03-2007, 01:33 AM   #14
UltimateBMW
399
Drives: MP4
LOL, this debate could go on endlessly. While some of you would overhang into the front 50% of the car... where would the rest of you be? In the BACK 50%. Do you really give the BMW M engineers so little credit that they wouldn't put the seat track as near the center line of the car as possible? As with all real measurements if you try to mess it up you easily can, ie moving the seat max forward or max rear. However, I think most people would probably sit near the middle of the seat tracking.
Anyways, 10 lbs might not matter I agree with you. But if your going to spend the extra 3-4 grand just for a CF hood that saves you a few pounds I'm sure you would want to get the most out of it as possible, 40 lbs vs 50 lbs is a 20% difference. And the lower the total pounds saved the bigger the % increase would be.
      12-03-2007, 10:19 PM   #15
Champagne
Champagne's Avatar
Sweden
13
Drives: E92 M3 Coupé
I believe that it's 50/50 with a driver of 75kg, 70kg luggage and 3/4 fuel.
      12-04-2007, 02:34 AM   #16
swamp2
swamp2's Avatar
Drives: E92 M3
It is 51.2%F/48.8%R as tested by German Sportauto. I suspect they use EU unladen standards which include 68kg driver, 90% fuel and 7kg luggage.
      12-04-2007, 07:35 AM   #17
Epacy
Reincarnated
Epacy's Avatar
245
2008 M3  [0.00]
Why would you quote f/r distribution with a driver involved? Doesn't seem like that would give an accurate assesment.
      12-04-2007, 07:38 AM   #18
Epacy
Reincarnated
Epacy's Avatar
245
2008 M3  [0.00]
Don't know how much the paint weighs for just the hood. However, in the recent National Geographic tour of the BMW plant in Spartanburg, they said paint adds 20lbs to the whole car of a Z4.
      12-04-2007, 01:12 PM   #19
swamp2
swamp2's Avatar
Drives: E92 M3
. I think the best way to quote weight balance would be exactly the same way weight itself is quoted. Per a particular standard and and standard that includes a driver. Were you just being sarcastic?
      12-05-2007, 08:34 AM   #20
Epacy
Reincarnated
Epacy's Avatar
245
2008 M3  [0.00]
No.
      01-02-2008, 10:15 PM   #21
OC ///M
Dr. Octagon
OC ///M's Avatar
I realize these are not representative of an e92 M3 but I just wanted to get the imagination going...
Here's a couple reference pics. Some choose not to paint or to use a blending of the cf with the body color, ie. just the powerdome cf blended to body color.
I took this at Bimmerfest last year:
This was from a local meet:
Reference link to meet
still looking for the "blended" pics...
OC ///M
      01-25-2008, 08:03 PM   #22
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
the stock hood is aluminum. $$ per pound of weight savings will be rediculous. thats IF there is any savings.
only worth it if you want the look. I dont.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
m3post
