2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions DIY: M Performance rear diffuser
      04-21-2014, 08:11 PM   #1
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Hi Gents,
Just another DIY for those looking to tackle a easy job. First if you plan on replacing the diffuser; make sure you chose if either you have M-Performance Exhaust. If you do not, chose the standard exhaust and you will need to get the adapters to extend the tips!
I am installing Performance exhaust tomorrow; so you will see why you will need the adapters if you do not have M Performance exhaust.
Tools needed:
  • 8mm socket with extension
  • Flathead screw driver or expanding rivet clip remover
  • Patiences
Difficulty 1-5 (5 being hardest): 2
Start by painting, or leaving your diffuser primed. I chose to paint my diffuser and than keep the center gloss black.
You can do this on the ground with no hoists if you have not lowered your car yet. Go underneath the vehicle and removing the six 8mm bolts. They have speed nuts on the exhaust shield.
Remove the expanding pin on both sides of the diffuser. They are right behind the 8mm. You will use a flat head screw driver here to pull these out.
Start by slowly pulling way on a corner you will hear the clips start to come loose from the bumper.
Installing the new bumper was a little tricky with the clips. They are extremely tight and require A LOT of force. I'm not exaggerating when I say a lot. I had to put all of my 180LBS into each clip right underneath with WD40 on top of the clip. Do not be surprised if you have to spend upwards of a minute pushing on some of the center clips.This photo shows the clips not all the way in.
Here is a photo after really pressing on the diffuser to get those clips in. Was rather painful!
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com
Current: 2015 Cayman S on HRE P101
tiwahu34.50
      04-21-2014, 08:29 PM   #2
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
Awesome...now i see why it needs the perf exhaust
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      04-21-2014, 09:14 PM   #3
Greenkirby21
Vrooom :)
Greenkirby21's Avatar
Drives: C7 Stringray
looks great!
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
      04-21-2014, 10:14 PM   #4
thomps
Drives: 2015 M235i
Overall, how do you feel about the appearance? Do you feel it's aggressive enough? I haven't been able to make up my mind on the M Perf diffuser based on pics.
      04-21-2014, 10:20 PM   #5
Cripple
Cripple's Avatar
102
Drives: 12' 335is
To be honest, I need to get the M Performance exhaust on to be sure. I do believe it makes the rear quite more aggressive. Something this car absolutely needs due to the plain rear end. The fins are VERY pronounced. I really do like that.
      04-21-2014, 10:23 PM   #6
thomps
Drives: 2015 M235i
Makes sense. Definitely think the exhaust will complete the look. But glad to hear the diffuser's features are pretty pronounced! That's what I was most curious about.
      04-21-2014, 10:25 PM   #7
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Also painting it gloss black really made them pop. The fins are 3 inches out from the base in terms of height
      04-21-2014, 11:22 PM   #8
Tim917
Drives: Often
What did it cost to paint?
      04-22-2014, 12:46 AM   #9
darcivic00si
Save the manuals!
darcivic00si's Avatar
Drives: Lotus Evora S
Thanks so much for the write up! Looks great!
      04-22-2014, 03:32 AM   #10
JustChris
JustChris's Avatar
Drives: Tesla MYRWD
Great write up great car, thank you again.
My car made front page of Bimmerpost
      04-22-2014, 07:27 AM   #11
Evan@Tischer
Evan@Tischer's Avatar
3361
Drives: Online Parts Sales
Great write-up!! Looks great...love the paint job with the black center!!!
Evan Winstead · Internet Parts Director
Contact Us | Facebook | Twitter | New: Shop Porsche & Audi parts!
      04-22-2014, 08:21 AM   #12
Sportstick
Sportstick's Avatar
4654
Drives: '15 228i and '24 X3 sDrive30i
I understand what you want to achieve, and the first photo looks great....well lit, looking up from below. The concern for me would be that one never sees it in that lighting or angle on the road. The second to last photo is much more representative, and unfortunately, the surface detail of the fins in black pretty much disappears.
I went through a similar exercise on another brand of vehicle not too long ago, and wound up painting the entire diffuser, just so I could see that I really had a diffuser there. Going from the original black CF to bodycolor made a huge difference.
      04-22-2014, 08:48 AM   #13
Cripple
Cripple's Avatar
102
Drives: 12' 335is
I'll take a more direct photo
      07-25-2014, 08:08 AM   #14
235newbie
Drives: M235i
has anyone added the diffuser with the standard exhaust using the adapters?
I'd love to see a photo of this if possible...
      07-25-2014, 09:03 AM   #15
dharo1
dharo1's Avatar
Drives: Previous: F22 M235i ; F80 M3 ;
Interested in this also
      07-25-2014, 08:33 PM   #16
ManCityFan
Drives: Evo IX MR
Me. Didn't want MPE. Eventually will go aftermarket for exhaust but wanted better looking tips in the meantime.
Pic here: http://www.2addicts.com/forums/showp...9&postcount=11
      07-26-2014, 05:44 AM   #17
235newbie
Drives: M235i
That looks good. What exactly am I looking at though? Have you used the adapters and added aftermarket tips? Which tips exactly?
      07-26-2014, 06:23 AM   #18
ManCityFan
Drives: Evo IX MR
M Perf tips and adapters. Note that u have to cut ~120mm off of the end of each exhaust pipe in order to fit the adapters. Not a big deal...just FYI.
      07-26-2014, 09:08 PM   #19
YYZF22N55
YYZF22N55's Avatar
Drives: 2014 M235i
What do the adapters look like?
      07-28-2014, 08:08 AM   #20
ManCityFan
Drives: Evo IX MR
~6" metal sleeves.
      07-28-2014, 08:21 AM   #21
YYZF22N55
YYZF22N55's Avatar
Drives: 2014 M235i
~6" metal sleeves.
Do you have a picture?
      07-28-2014, 08:41 AM   #22
ManCityFan
Drives: Evo IX MR
no pic.
2addicts
