Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > M3/M4 versus...
View Poll Results: Faster, Slower or Same as the M3 GTS ?
Faster 52 78.79%
Slower 7 10.61%
Same 7 10.61%
Voters: 66. You may not vote on this poll
      03-28-2014, 03:53 PM   #1
Flying Brick
Drives: m
Potential of the New M4, Faster or Slower then the M3 GTS ?
Since there is not much going on and no new information being released on the M4 any time soon. What's your speculation on the the New M4, Faster, Slower or Same as the M3 GTS.
Specs on the M3 GTS
450 BHP (4.4l V8)
1490 kg / 3278 lbs (DIN standard)
6 / 4 piston brake system
6 point harness
255 35 19 F
285 30 19 R
Rollbar behind the front seats ( only 2 seats )
Front splitter and Spoiler ( adjustable )
Performance
Nordschleife
BMW M3 GTS 7:48.00
BMW M3 E92 8:05
Max speed 305 kph (189.1 mph)
0 - 50 kph 1.8 s
0 - 100 kph 4.3 s
0 - 130 kph 6.3 s
0 - 200 kph 13.1 s
0 - 100 mph 8.9 s
1/4 mile 12.3 s
Engine
Power 331 kw (444 bhp / 450 ps) @ 8300 rpm
Torque 440 Nm (326 lb-ft) @ 3750 rpm
      03-28-2014, 04:00 PM   #2
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Here's my speculation: M4 may be faster in the short sprint but the M3 GTS would probably win the endurance race.
      03-28-2014, 04:07 PM   #3
Flying Brick
Drives: m
They Both are almost the same weight. But the M4 has 100 more Torque.
Also it will be very easy to tune the m4. Just chipping it would give u easily 80 hp.
      03-28-2014, 04:11 PM   #4
Boss330
Boss330's Avatar
The new M4 is at least 10s faster round the Nurburgring than the E92 M3.
How much faster was the GTS?
(a time set on similar tires obviously)
If you compare those times you should get a good indication on relative performance.
      03-28-2014, 04:15 PM   #5
Flying Brick
Drives: m
BMW GTS Nordschleife 7:48.00
BMW M3 E92 8:05
      03-28-2014, 04:22 PM   #6
CanAutM3
CanAutM3's Avatar
Drives: 2021 911 turbo
My guess is that the M4 will be faster with the same tires as the GTS.
For this, I am assuming that the S55 is underrated and that it actually produces 440-450hp
      03-28-2014, 04:26 PM   #7
Boss330
Boss330's Avatar
BMW M3 E92 8:05
The GTS was only 2s faster than the E46 CSL, and 17s faster than the regular E92 M3.
swamp2 has done simulations and I believe that he expects the M4 to be something like 15-20s faster than the E92 M3 around the Ring. BMW has claimed "at least 10s"...
      03-28-2014, 04:28 PM   #8
CanAutM3
CanAutM3's Avatar
As you stated yourself, the tires are a huge variable
      03-28-2014, 05:58 PM   #9
Maddict3
Maddict3's Avatar
192
Drives: 2015 991 GT3
The M4 will be faster
      03-29-2014, 02:24 AM   #10
ZGM3
Drives: bmw
The M4 will be the fastest manual of any previous generation M3/GTS!!!
      03-29-2014, 03:30 AM   #11
Flying Brick
Drives: m
M3 GTS was fitted with a 7-speed M dual clutch transmission, which is proven to be faster then the manual transmission.
      03-29-2014, 03:56 PM   #12
ZGM3
Drives: bmw
The new M3 will still be the fastest manual since the GT3 did NOT have a manual transmission as you clearly stated above...
My fist post was meant to be taken as a bit of humor, but since I refuse to use little smiley faces in my posts I could see how my sarcasm would not translate well in the written form.. My bad...
      03-29-2014, 04:57 PM   #13
duk
///M
Drives: 2011 AW/FR 6MT E92
Nordschleife
BMW M3 GTS 7:48.00
BMW M4 7:??:??
My vote will be that the GTS is a tad faster than M4.
2011.5 AW/FR E92 M3 6MT
      03-29-2014, 05:36 PM   #14
Hedoniste
Hedoniste's Avatar
Drives: M2 CS | M135i
2020 BMW M2 CS  [10.00]
I had the chance to be passenger in my friend's GTS (around the Ring) and to drive it (carefully) on public roads. All I want to say is that it doesn't matter which one is faster because the M4/M3 will never be as track focused than a GTS. It's just amazing how this car is different than a regular M3. When I drove back my E92 zcp I had the feeling I was driving a Prius...
2020 M2 CS DCT
2021 M135i xDrive
ex: 18 M3 DCT ZCP | 15 M3 DCT | 11 M3 Coupe 6MT ZCP | 07 M Coupe
      03-29-2014, 05:37 PM   #15
karussell
Drives: 4 wheels
Given the M4 will likely be equipped with Michelin Pilot Super Sports versus the GTS's Pirelli Corsa's I think it will still be close time to the GTS. given a set of Pilot Sport Cup II's I think its gonna be surprisingly fast. I will wager a 7:39 lap is possible on PSC-2. 7:49 on PSS.
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
      03-29-2014, 09:01 PM   #16
Tonymiabmw
Tonymiabmw's Avatar
552
Drives: Nardo F90 M5 on order
Ha I wish, we will not see a chip for a long time. No one can crack the computer yet.
      03-29-2014, 09:17 PM   #17
Lups
Lups's Avatar
11825
Drives: I don't own a car.
You still made me laugh, I'll sue you if my muscles hurt in the morning.
      03-29-2014, 10:08 PM   #18
Flying Brick
Drives: m
True, But a year down the road you are going to have some software.
They have a flash for 435i which give you 100 hp at the crank. So 80 to 100hp is something we can expect for the M4/M3.
      03-29-2014, 10:24 PM   #19
Flying Brick
Drives: m
Well, True to some sense about the track focused part. But the New M4 was developed strictly around the Nordschleife. Plus the Curb weight of the 2 cars is very similar. M4 has more torque 406 vs 326 which hits at much lower rpm. Dry carbon drive shaft. Even the suspension is bolted directly to the Chassis, which was Tuned by DTM drivers.
"The suspension is a familiar strut-type front end with a multi-link rear. BMW says it took advantage of its DTM drivers Bruno Spengler and Timo Glock in the development of the 2015 M3 and M4 suspension settings, including extensive testing at the Nürburgring-Nordschleife. New aluminum suspension elements reduce unsprung weight."
      03-29-2014, 10:49 PM   #20
BlackLight
BlackLight's Avatar
Drives: E92 M3
Exclamation Mmm
...Plus the Curb weight of the 2 cars is very similar... M4 has more torque 406 vs 295 which hits at much lower rpm...
M3 GTS:
Weight: 1490 kg / 3278 lbs (DIN standard)
Torque: 440 Nm (326 lb-ft) @ 3750 rpm
      03-30-2014, 02:53 AM   #21
solstice
Drives: 2015 M3 6MT
I think the GTS will eat the M4 on the track unless the driver is a pro. But I assume a future special version M4 will be wickedly fast and spank all prior M3s.
      03-30-2014, 08:24 AM   #22
Rupes
Rupes's Avatar
Drives: F87 M2 (current), E90 330xi (w
The 435 is a mix of luxury, power, reliability and fuel efficiency. It's easy to get extra power by sacrificing some of the other attributes. The M3/M4 is a much more focused on the sport side of the equation out of the box. Don't you think if 80-100 extra HP was available from software, the M division would have done it themselves? I think your a bit optimistic with these claims.
f80post
