FS: CIC Retrofit with DAB - Complete kit SOLD
02-04-2014, 01:59 PM | #1 |
Rep 135
I'm selling my CIC retrofit with DAB - an option that's pretty hard to find, and you can't retrofit factory DAB to a CIC that doesn't have it.
The kit has everything you need to retrofit from CCC to the infinitely better CIC setup. CIC unit Screen Video Cable (Between screen and CIC) USB Port and Cable Screen connector (used to replace the CCC connector) CIC controller complete with E9x frame Bimmer Retrofit Emulator - enables Nav, Voice and Video in Motion Fascia plate for CIC unit I have a 5m DAB aerial cable that is unused, and will include this. I have the VIN for the CIC unit, have recently installed the 2014 Premium maps and have a lifetime FSC code from a well known seller. The unit is in full working order. £800 shipped to the UK
Past Previous: E92 335i, CIC retrofit, JB+, Perf Exhaust Last Car: MB ML350CDI, X800D-ML Retrofit, AMG Steering wheel, Brabus tuning box Current car: F31 335d - NBT EVO ID6 retrofit, 3AG retrofit, Coded EBT, Deleted RFTs!! Last edited by jozza66; 02-13-2014 at 04:04 PM.. Reason: Added detail to listing, price drop. |
02-08-2014, 09:29 AM | #2 |
Rep 135
Bump and price amended.
Past Previous: E92 335i, CIC retrofit, JB+, Perf Exhaust Last Car: MB ML350CDI, X800D-ML Retrofit, AMG Steering wheel, Brabus tuning box Current car: F31 335d - NBT EVO ID6 retrofit, 3AG retrofit, Coded EBT, Deleted RFTs!! |
02-09-2014, 04:37 AM | #5 |
Rep 135
Makkan on this board is a good shout for fitting & coding. Has a great reputation and is happy to tackle retrofits both simple (CCC to CIC) and complex (no Nav to full CIC plus dash)
It takes me just over an hour to remove or install - you need to be careful with the CIC screen connector swap, and of course do the whole thing with the -ve terminal disconnected on the battery. As for coding, will of course depend on the options on your car, but when I had it remote coded after I first fitted it, it took about 20mins total. Thanks. John
02-09-2014, 04:39 AM | #6 |
Rep 135
RealOEM shows the production date as 08/11 from the CIC VIN. I'm not sure whether it's happy with Combox/6NR retrofits, as I just had mine using the existing MULF in my 2006 build E92 . . .
02-13-2014, 12:55 PM | #7 |
Rep 135
Provisionally sold.
